Trigonometric Equation solving
The forum discussion focuses on solving the trigonometric equation cos(2x) + cos(4x) = cos(x) within the interval of 0 degrees to 360 degrees. Participants explore various trigonometric identities and methods, ultimately determining that the solutions include x = 20°, 90°, 140°, 260°, 270°, 100°, 220°, and 340°. The discussion emphasizes the importance of correctly applying identities and factoring expressions to avoid losing potential solutions.
  • Understanding of trigonometric identities, specifically cos(u + v) and cos(2x) = cos²(x) - sin²(x).
  • Ability to manipulate and solve trigonometric equations.
  • Familiarity with the unit circle and angle measures in degrees.
  • Basic algebraic skills for factoring and solving equations.
  • Study the derivation and application of trigonometric identities, particularly sum-to-product identities.
  • Practice solving trigonometric equations using various methods, including factoring and substitution.
  • Explore the unit circle to understand the angles corresponding to specific cosine values.
  • Learn about the implications of dividing by variable expressions in equations to avoid losing solutions.
Students studying trigonometry, educators teaching trigonometric equations, and anyone looking to improve their problem-solving skills in trigonometric contexts.
bnosam
cos 2x + cos 4x = cos x
0 degrees ≤ X ≤ 360 degrees
Trig identities.
Trig identities and equations are my weakness so I'm trying to review some to get better at them, so I guess this isn't technically homework. But it's out of my textbook.
Can someone give me a kick for the right start?
I tried:
2cos(\frac{(2x + 4x)}{2}) cos(\frac{(2x-4x)}{2})
2cos3x * cosx = cosx
2cos3x = 1
cos3x = 1/2
I'm not sure if this is right or where to go from here.
As stated, it's not clear what you need to do. Are you supposed to solve an equation or prove an identity? From your work below, you are apparently solving an equation.
bnosam said:
Trig identities.
I tried:
How is this related to cos(2x) + cos(4x)? It could be that the above equals cos(2x) + cos(4x), but this is not an identity that I have committed to memory.
2cos3x = 1
Assuming for the moment that your work is correct, you should never do what you just did, since you lost a bunch of solutions. You pretty much never want to divide by a variable expression, because it's possible that expression might be zero for some value(s) of the variable.
Instead, bring everything over to one side, and then factor it.
bnosam said:
cos3x = 1/2
Can you solve cos(b) = 1/2?
2cos3x * cosx = cosx *
2cos3x = 1
cos3x = 1/2
On line *, where you 'divide out' by cosx, you are implicitly assuming cosx is not zero here, that is that x is not ##\pi/2 + n\pi##. Do you think this is wise?
Trying to solve the equation to find the angle.
It is related to cos(2x) + cos(4x) because those are the identities for addition of cos.
cos u + cos b = 2cos((u+v)/2) * cos((u-v)/2)
So I guess what I did was wrong then? So I have no idea where to go, unfortunately.
I just find everything in trig so far to be confusing, I was just starting to understand using the identities and so on, but coming to this, just confuses me and I can't get around the mental block of it.
I didn't say that. The identity you used is fine, I believe. It's just not one that I've used a lot.
You got to here:
2cos(3x)cos(x) = cos(x)
Bring everything over to one side and then factor what you have.
You got to here:
2cos(3x)cos(x) - cos(x) = 0
cos(x) ( 2cos(3x) - 1) = 0
so cos(x) = 0
x = 90 , x = 180
2cos(3x) - 1 = 0
2(cos(3x) = 1
cos(3x) = 1/2
IS this right so far?
so cos(x) = 0
x = 90 , x = 180
2cos(3x) - 1 = 0
2(cos(3x) = 1
cos(3x) = 1/2
Mostly. cos(x) = 0 ==> x = 90° but does not imply that x = 180°. cos(180°) = -1.
Everything else looks fine.
A question I asked earlier was this: Can you solve cos(b) = 1/2?
Oops, wasn't thinking when I put 180. I meant 270.
cos(b) = 1/2
b = 60 degrees
cos 3x = 1/2
cos x = 60
3x = 60
x = 20So it checks correct when I sub it back in the equation. Did I get everything?
cos(b) = 1/2
b = 60 degrees
Actually, b = 60° + k * 360°, where k is an integer
bnosam said:
cos 3x = 1/2
[STRIKE]cos x = 60[/STRIKE]
3x = 60
x = 20
3x = 60° + k * 360°, where k is an integer
So x = ?
You want values of x such that 0 ≤ x ≤ 360°
See above.
So x = ?
See above.
So x = ?
would it be 20° + k * 360°?
So x = ?
No.
You're multiplying both sides of the equation 3x = 60° + k * 360°, but you forgot to distribute the 1/3 to both terms.
Mark44 said:
No.
x = 20 + (360k)/3
bnosam said:
x = 20 + (360k)/3
Yep. And (360k)/3 = ...k ?
120k
Yes, but you're not quite finished.
So x = 20° + k * 120°, for k an integer.
In the problem statement, 0° ≤ x ≤ 360°, so what values of k give x values in this range?
I think you will be missing solutions. How will you get x=100°,220°, or 340° from this? cos(3x)=1/2 does not mean that 3x=60°+360°k for integer k.
mark44 said:
yes, but you're not quite finished.
20 + 1 * 120 = 140
20 + 2 * 120 = 260
bnosam said:
20 + 1 * 120 = 140
20 + 2 * 120 = 260
0 is an integer too! :-p
So, what is our complete solution set? Id est,
$$\cos{2x}+\cos{4x}=\cos{x} \\ (0^o \leq x \leq 360^o) \\ \forall x\in\{?\}$$
Our answers should be: 90°, 270°, 20°, 140°, 260°
Reread my post #16. There are other solutions you can get from saying 3x=300+360k. You will see that x=100°,220°, and 340° will also satisfy your equation.
Ok thank you. I understand this now.
I have another question that I'm not quite sure with.
sin3x = sinx
I tried
sin(2x + x) = sinx
sin2xcosx + cos2xsinx = sinx
sin2xcosx + cos2xsinx - sinx = 0
sin2xcosx + sinx(cos2x - 1) = 0
sin x = 0
x = 0, 180, 360
cos 2x -1 = 0
cos 2x = 1
2x = 0 + 360k
x = 180k
x = 0,180, 360 also.I'm a little stuck so far now
sin3x = sinx
I tried
sin(2x + x) = sinx
From here, one thing to try would be substitute an alternate expression for cos2x such that the LHS is entirely in terms of sinx.
sin x = 0
x = 0, 180, 360
cos 2x -1 = 0
cos 2x = 1
2x = 0 + 360k
x = 180k
x = 0, 180, 360 also.
##a + b = 0 ## does not mean that ##b## need be zero.
Let me show more work then and see if this is what you mean:sin(2x + x) = sinx
sin2x cosx + cos2x sinx = sinx
sin2x cosx + sin2 (x) sinx - sinx = 0
2sinx cos2(x) + sin3(x) - sinx = 0
sinx(2cos2(x) + sin2(x) - 1) = 0
sin x = 0
(2cos2 (x) + sin2(x) - 1) = 0
2sin2(x) + sin2(x) -1 = 0
3sin2(x) -1 = 0
sin2(x) = 1/3
sinx = ± \frac{√3}{3}
Correct so far?
sin(2x + x) = sinx
sin x = 0
2sin2(x) + sin2(x) = 0
How did you get the equation above?
bnosam said:
3sin2(x) -1 = 0
sin2(x) = 1/3
Correct so far?
I'm not quite sure what you mean, did you mean the sin ( 2x + x)?
If so:
sin(U + V) = sin U cos V + cos U sin V
No, I meant the equation directly above my question: 2sin2(x) + sin2(x) = 0.
How does this follow from 2cos2(x) + sin2(x) - 1 = 0?
It was a typo, sorry. I corrected it on the post above
"Corrected" is the wrong word. You just made it different, but no correct.
How did you go from
to
2sin2(x) + sin2(x) - 1 = 0
There is no identity that says that cos2(x) = sin2(x).
How did you go from
to
My book has cos 2x = cos2(x) = sin2(x) as an identity in the list of identities...
It must be a typo in the book, the identity must be cos 2x = cos2x - sin2x.
So confusing, no wonder my answer was wrong!
Either you're not reading your book correctly, or the book has a typo in a very important identity.
It should read cos 2x = cos2(x) -[/color] sin2(x)
That's "minus" NOT "equals".
