Triple Integral, Volume of an Egg
The discussion revolves around finding the volume of a shape described by two surfaces: a paraboloid opening upwards and another opening downwards. The problem involves setting up a triple integral to calculate the volume of the region enclosed between these two surfaces, which is referred to as an "egg." Participants are also considering the implications of the given length of the egg and the intersection of the surfaces.
  • Mixed
  • Participants discuss the setup of the triple integral and the limits of integration for the volume calculation. There are considerations of using cylindrical coordinates and the nature of cross sections parallel to the xy-plane. Questions arise regarding the integration limits and the relationship between the surfaces and the radius of the cross sections.
There is an ongoing exploration of the correct setup for the triple integral, with some participants suggesting sketches and reconsideration of coordinate systems. Guidance has been offered regarding the integration limits and the interpretation of the intersection of the surfaces. Multiple interpretations and approaches are being discussed, with no explicit consensus yet.
Participants are working under the constraint of needing to use a triple integral to solve the problem, and there is a focus on understanding the geometric implications of the surfaces involved. The maximum radius for integration has been identified as a point of confusion, with discussions about the intersection of the surfaces influencing the limits of integration.
ktvphysics
I need to find the volume of an egg with a shape described by:
z = 1/2(x2 + y2) and z = 6 - x2 - y2
I am also given that the egg is 6cm in length.
I roughly graphed the two surfaces. The first being paraboloid that opens up from the origin, and the second being a paraboloid that opens down from z =6. The region under these two surfaces is the "egg."
I don't know where to begin to set this up. I know that the region I need is the region in between the two curves. I assume I integrate dz from 0 to 6. I don't know where to go from there.
Sometimes, it's helpful to make a rough sketch of the two regions. The volume contained within the 'egg' is going to be under the upper surface, but above the lower surface, so this gives an indication on how to set up the z portion of the volume.
Yes, I agree. What you said is basically my progress so far.
I'd do this as a volume of rotation.
Are you instructed to do it via a triple integral?
Yes, I must solve with a triple integral.
It may help if you also try to sketch what slices parallel to the xy plane look like, to get a better idea for the parameters. In addition, perhaps you may consider a different coordinate system than Cartesian.
I know that the intersection of the two surfaces forms a plane that is a circle of radius 4. (I set the z equations equal to each other and found x^2 + y^2 = 4). Is every cross sectional area a circle, or is that only in this instance? After thinking about it, I am retracting my statement in the original post about integrating dz from 0 to 6. I should integrate dz from z=1/2(x^2+y^2) to z=6-x^2-y^2, correct?
I think I know how to solve it using a triple integral now. Solve it as a volume of rotation and we can compare answers, if you would like.
At any cross section parallel to the xy plane, you can consider z to be a constant (i.e. at z=3) with only x and y varying to make the shape. So If you consider z to be any constant, what do the equations z=6-x^2-y^2 and z=1/2(x^2+y^2) become, for any arbitrary constant value of z?
TheGeometrist said:
At any cross section parallel to the egg, you can consider z to be a constant (i.e. at z=3) with only x and y varying to make the shape. If you consider z to be any constant, what do the equations z=6-x^2-y^2 and z=1/2(x^2+y^2) become, for any given value?
Circles. Got it. So is this how I set it up?
∫∫∫ rdzdrdΘ , integrating dz from z= 1/2(x^2+y^2) to z = 6 - x^2 - y^2, dr from 0 to 4 and dΘ from 0 to 2π
Close. The integration values for z are still in terms of x and y, while you are integrating in Cylindrical coordinates. It seems otherwise correct to me.
Ah, okay. I would have ran into that issue when I tried to solve it I guess. So x^2 + y^2 = r^2, yes?
Can you explain why I integrate dr from 0 to 4? Why not 0 to 3? what does the intersection of the surfaces have to do with it?
Actually, sorry, I made a mistake as far as the integration of dr. Remember that r is of course the radius, and dr is being integrated from the minimum value of the surface to the maximum value. We can agree that it has a minimum of 0 (i.e. At z= 0, 6). In this case, the top function would keep expanding in radius in the negative z direction, and the bottom function would keep expanding in radius in the positive k direction. Therefore, the maximum value will have to be where the two intersect. Now what would the radius be at this maximum value?
The intersection of the surfaces sets the maximum width of the volume - you should be able to see that from your diagram.
Try taking a slice through the z-x plane. This means it determines some of the limits of the integration.
Note: You would expect r to be a function of z, since this is the radius of the circle you get when you slice perpendicular to the z-axis.
I'm not sure what you mean by that last bit... The part about the slice through the z-x plane
The maximum value of the radius is 2, right? x^2 + y^2 = 4. sqrt(4) = 2. That was my mistake, I forgot to take the square root of 4. So I would integrate dr from 0 to 2, correct?
Integrate what from 0-2?
Go carefully back to your setup.
You can tell if you got it correct by considering that you know the equation for the area of a circle.
Integrate the radius from 0 to 2.
I got 12pi for my final answer.
∫∫∫ r dzdrdΘ. 1/2r^2≤z≤6-r^2, 0≤r≤2, 0≤Θ≤2π = 12 pi
