Trouble Graphing Multivariable Functions
The function f(x,y) = 1/sqrt(1-x^2-4y^2) has a domain defined by the inequality x^2 + 4y^2 < 1 and a range of (0,1]. The discussion highlights difficulties in sketching level curves and cross sections, particularly in determining appropriate values for k when setting f(x,y) = k. It is noted that for level curves, k must be chosen such that 0 ≤ 1/k ≤ 1, ensuring valid outputs from the function. Understanding the relationship between k and the domain is crucial for accurate graphing. Insight into graphing techniques and visualization methods is requested to aid in sketching the function.
_Steve_
So the function I'm working with is:
First, they want me to find the Domain and Range, which I found to be:
D: x^2 + 4y^2 < 1
R: (0,1]
Then they want me to sketch level curves and cross sections, then sketch f(x,y)
I'm having trouble with the sketching, I understand the concept of level curves, but when I make f(x,y) = k I'm not quite sure where to go from here... Does anyone have any graphing tips that I could use? Thanks!
i wouldn't mind some insight on this as well.
You know that 0 ≤ x2 + 4y2 because x2 & y2 are each non-negative.
∴ 0 ≤ x2 + 4y2 > 1
So to find level curves, you must choose k so that 0 ≤ 1/k ≤ 1 .
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 27 ·
