Trouble solving this differential equation
BViper
im having a lot of trouble solving this differential equation. can someone please help.
initial conditions: y(0)=0.1
y'(0)=0
30000*y''+1462163*y+100000*y'=A*sin(6.98t)
im trying to get A (the amplitude). thanks for the help
"A" is not uniquely determined by the conditions that you gave. Varying "A" would change the solution to the equation, but the solution would still exist.
Are you looking how to solve y(t)?
cookiemonster
yeah that's it.. got to get y(t) before i can get A
No, you don't need to get y(t) before you get A. As I said before, A is not uniquely determined in this problem. The problem does not require that A take a single value or even a finite number of values. A could be anything (okay, almost anything) and y(t) would still exist.
If you'd like to solve for y(t) in terms of A and t, then that can be done. If you'd like to do that, then perhaps you could supply more information regarding what method you want see (perhaps one you've been using recently?).
cookiemonster
implicit differentiation...
initial conditions:
y(0)=0.1
y'(0)=0
[/color]
Uncertain if this approach is correct...
Implicit Differentiation:
ay" + by + cy' = A*sin(d*t)
(d/dt)[ay" + by + cy'] = (d/dt)[A*sin(d*t)]
(d/dt)[ay"] + (d/dt)[by] + (d/dt)[cy'] = (d/dt)[A*sin(d*t)]
a(dy"/dt) + b(dy/dt) + c(dy'/dt) = A(d/dt)[sin(d*t)]
a(dy"/dt) + b(dy/dt) + c(dy'/dt) = A*cos(d*t)
Orion1: The only variables mentioned in this problem are y and t.
y' and y" already ARE the derivatives with respect to time. There is nothing gained by differentiating again.
Cookiemonster's point was correct: the initial value problem:
initial conditions:
y(0)=0.1
y'(0)=0
Has a unique solution for every possible value of A. It is impossible to "determine A" from what is given.
Thread 'Direction Fields and Isoclines'
I sketched the isoclines for $$ m=-1,0,1,2 $$. Since both $$ \frac{dy}{dx} $$ and $$ D_{y} \frac{dy}{dx} $$ are continuous on the square region R defined by $$ -4\leq x \leq 4, -4 \leq y \leq 4 $$ the existence and uniqueness theorem guarantees that if we pick a point in the interior that lies on an isocline there will be a unique differentiable function (solution) passing through that point. I understand that a solution exists but I unsure how to actually sketch it. For example, consider a...
