MHB Troubleshooting a Trigonometric Integral: Algebra and Solutions
  • Thread starter Thread starter Kristal1
    Integral Trig
The discussion centers on troubleshooting a trigonometric integral involving algebraic manipulation and substitution. The original poster questions the validity of their algebra and seeks clarification on the correct approach to using trigonometric substitution. Participants highlight the importance of correctly determining the differential when substituting variables and provide two methods for performing the substitution effectively. The conversation emphasizes the need for clear guidance in understanding derivatives in the context of substitutions. Overall, the thread serves as a resource for improving skills in handling trigonometric integrals and algebraic techniques.
Kristal1
I have a few questions and a request for an explanation.
I worked this problem for a quite a while last night. I posted it here.
https://math.stackexchange.com/questions/3547225/help-with-trig-sub-integral/3547229#3547229
The original problem is in the top left. Sorry that the negative sometimes gets cut off in the photo, and yes I know it's not fully simplified there.
My first question is the more involved one: Is the algebra in my original work sound? If it is, why doesn't it work in this instance?
My second question is: is this a correct solution? https://imgur.com/2tgEz0O
It is for webwork, and I used two out of three chances. I'd prefer to keep my perfect webwork mark, obviously ;p
Finally, I was kind of impressed with Ans4's square completion and had to run it through to see that it was correct. That's such a useful skill. Do you have some advice about how I could improve my math tricks to that point?
Looks like you did this (correct me if I'm mistaken) ...
$$-7\int \dfrac{x^2}{\sqrt{4x-x^2}} \,dx = -7\int \dfrac{x^2}{\sqrt{x}\sqrt{4-x}} \,dx = -7\int \dfrac{x^{3/2}}{\sqrt{4-x}} \,dx$$
from here, I see you attempted to use the trig sub $\sqrt{x} = 2\sin{\theta}$.
you made a mistake determining $dx$ ...
$\sqrt{x} = 2\sin{\theta} \implies x = 4\sin^2{\theta} \implies dx = 8\sin{\theta}\cos{\theta} \, d\theta$
I did sub it in as a replacement for $\sqrt{x}$ though.
I posted this elsewhere since I wasn't even sure if it would be approved here. There it was suggested that I should have put $4cos\theta=\frac{1}{\sqrt{x}}dx$
This is an important conceptual point, though. Are you saying that this is the only correct derivative because dx means wrt x and not x to some power?
If so, well it would be nice if a teacher told us these things sometimes...
Hi Kristal, welcome to MHB! ;)
There are 2 ways that are generally taught to do a substitution.
You have the integral
$$\int \frac{x^{3/2}}{\sqrt{4-x}}\,dx$$
and you want to replace $\sqrt x$ by $2\sin\theta$.
Method 1
Write $x$ as a function of $\theta$ and take the derivative as skeeter suggested:
$$\sqrt x=2\sin\theta \implies x=4\sin^2\theta \implies dx=d(4\sin^2\theta) = 8\sin\theta\cos\theta\,d\theta$$
We can now replace $\sqrt x$ and $dx$ to find:
$$\int \frac{x^{3/2}}{\sqrt{4-x}}\,dx = \int \frac{(2\sin\theta)^{3}}{\sqrt{4-(2\sin\theta)^2}}\,d(4\sin^2\theta)
= \int \frac{(2\sin\theta)^{3}}{\sqrt{4-(2\sin\theta)^2}}\cdot 8\sin\theta\cos\theta\,d\theta$$
Method 2
Take the derivative left and right, and do what needs to be done to eliminate $x$.
In this case:
$$\sqrt x=2\sin\theta \implies d(\sqrt x)=d(2\sin\theta) \implies \frac 1{2\sqrt x}\,dx= 2\cos\theta\,d\theta
\implies \frac{dx}{\sqrt x} = 4\cos\theta\,d\theta$$
Rewrite the integral a bit to match and substitute:
$$\int \frac{x^{3/2}}{\sqrt{4-x}}\,dx = \int \frac{x^2}{\sqrt{4-x}}\cdot\frac{dx}{\sqrt x}
= \int \frac{(2\sin\theta)^4}{\sqrt{4-(2\sin\theta)^2}}\cdot 4\cos\theta\,d\theta
We can see that the result is the same in both cases.
I'm afraid I can't comment on what your teacher is telling you since I don't know what that is.
We can only point out and show what the correct math is.
my calculator’s CAS worked out these antiderivatives ...
