"Glossary"... kind of important
x ⇔ the 8-digit number.
Dn ⇔ Digit.
z ⇔ place-value exponent of a given Dn. (Dn x 10z)
n ⇔ number label of any digit Dn.
m ⇔ 9 - n. Specifies to what multiple x should be rounded down to given n.
R(x) or any variations thereof ⇔ Round down function. Can be given in terms of the truncation function, T(x). SEE A.
T(x) or any variations thereof ⇔ Truncation function. Can be given in terms of the floor function.
NOTE: I use the "round down" function here, which may or may not be the same thing as ROUNDDOWN in Excel. Probably not, I don't know the slightest thing about Excel.
This is how Wikipedia defined roundm(x), where round(x) is defined as "rounding x to the nearest multiple of m" or "round x to the nearest mth":
"Divide x by m, let the result be y;
Round y to an integer value, call it q;
Multiply q by m to obtain the rounded value."
So rounding 15 with m = 10, or rounding 15 to the 10ths place:
Divide x = 15 by m = 10... y = 1.5.
Round y = 1.5 to the nearest integer... q = 2.
Multiply q = 2 by m = 10... 20.
And...
A
This is how I'll define my round down function Rm(x), which means "round down x to the nearest mth's":
Truncate y to 0 decimal places, call it q;
So if you want to do this for 00123456 for m = 104, you would divide first:
00123456/(104) = 0012.3456
then truncate:
T(0012.3456) = 0012
then multiply by m = 10^4
0012 * 10^4 = 00120000.
So R104(00123456) = 00120000.
You'll see where I'm going with this.
But basically: R_{10^m}(x) = m*T(\frac{x}{m})
I believe in Excel-language that would be m*TRUNC(whatevercellhas[x/m], 0)
NOW:
Most importantly, we know that x has 8 digits:
{D1|D2|D3|D4|D5|D6|D7|D8} ... which I will denote like so for the sake of organization.
Expanded, it looks like this:
D1*107 + D2*106 + D3*105 + ... + D8*100
First off, D8 can be extracted as a single digit by taking x, and rounding down x to the place value to the left of D8 -- otherwise stated as rounding x down to the nearest multiple of 101 and written as
R101(x)).
The operation returns this number:
{D1|D2|D3|D4|D5|D6|D7|0|}
Which when subtracted from x, or {D1|D2|D3|D4|D5|D6|D7|D8|}, returns {D8}.
So written concisely,
D8 = x - R101(x).
Obviously this only extracts a single-digit number in the sole case of D8, (ex: 12345678 - 12345000 = 678 doesn't work), and for everything else it extracts every digit to the right of that one.
So we need to cut off some numbers. For m = 1, it returns one digit, and for m = 2 it returns two. We only want the left-most digit, so we can cut it off by dividing by 10m-1 (note that after taking the difference of x and rounded x, there remains only m digits, so removing m-1 of them is appropriate) and truncating the decimals:
T(\frac{x-R_{10^m}(x)}{10^{m-1}}) = Dn
Now, note that:
D8 -> uses m = 1 for extraction of digit
D7 -> uses m = 2 for extraction of digit
D1 -> uses m = 8 for extraction of digit
So for any digit Dn, m + n = 9.
Also note that:
D8 is raised to the 100 in x.
D7 is raised to the 101 in x.
D1 is raised to the 107 in x.
So for any digit Dn, n + z = 8, where z is the original power it was raised to.
n = 9 - m
n = 8 -z
z = m - 1.THIS IS SUPER IMPORTANT THIS IS SUPER IMPORTANT THIS IS SUPER IMPORTANT
f(x) is the sum of all the digits times 10 raised to the original power z x 2...
In other words:
f(x) = \sum_{n=1}^{8} Dn^{2z}
Don't believe me? Try it out yourself. Every digit, in essence, is shifted up twice its original place (where ones-place = 0, tens-place = 1, hundreds-place = 2, etc.)
It's great that it worked out so easily, or else our f(x) would be terribly ugly.
Now we simply compile everything we know:
As I already showed, T(\frac{x-R_{10^m}(x)}{10^{m-1}}) = Dn.
We can substitute that in, and write it all in terms of m using the the relation:
z = m - 1.
This is it:
f(x) = \sum_{m=1}^{8} T\left (\frac{x-R^-_{10^m}(x)}{10^{m-1}} \right )10^{2(m-1)}
"Glossary"... added here again for convenience
Dn ⇔ Digit.
I'm pretty sure I've made some dumb mistake somewhere, but you get the general idea. Round, subtract, truncate, multiply it by double the magnitude of the original, rinse and repeat 7 more times, add 'em all up from D1 to D8. Also, I'm not sure what kind of math this is categorized under, but it sure was fun working it out.
