Trying to simulate a square wave. NOT WORKING
24 replies · 11K views · last reply
omonoid
For my extra credit project i am building a simple square wave osc i am trying to simulate the schematics in Multism, a program i just learned today.
Here are the original schematics:
Schematic of a square wave generator using a uA741 op-amp (IC1) with R1 2.5M, R2 47K, R3 100K, R4 10K, C1 and +9V/-9V supplies, output taken from pin 6.
more info on the circuit is found http://www.circuitstoday.com/square-wave-generator-using-ua-741"
These are my schematics suppositly replicatinmg the ones above. The ocilliscope just shoots up then remains blank.
Multisim schematic of a 741 op-amp square wave generator with R1 47kΩ, R3 100kΩ, R4 10kΩ, C1 0.01µF, a 2.5MΩ potentiometer, and a 9 V supply, with an oscilloscope XSC1 whose trace is flat.
Thanks
You might try two 9-volt batteries, with the midpoint connected to the common ground.
Bob S
It seems to me there is a jumper where C1 should be. Did you intend that. If you replace it with a capacitor, does it work?
no that didnt work i aslo saw that as a possible problem. It is now a cap
It takes a long time to charge C1 before the multivibrator starts. Wait at least 0.25 sec before starting plot. See thumbnail.
Bob S
  • LTspice screenshot of an op-amp astable multivibrator circuit with U1 LT1014, R1 47k, R2 100k, R3 10k, C1 0.01µF, supplies V1 -9 and V2 9, and a .tran 0 0.205 0.2 0.0001 directive; below, a plot of V[vout] shows a square wave swinging between about -8V and 8V over 0 to 5 ms.
It also looks to me like you have the inverting and non-inverting inputs reversed from the example.
omonoid, I just created and ran your circuit and get a beautiful square wave with a frequency of about 210 Hz. I think if you reverse your inputs it will work.
You build the circuit yet to proof it works? I agree with Bob S that you need to put two 9V battery and put the middle to ground. In your simulation, you don't have a ground reference anywhere. Even if you build the circuit as in the simulation, it won't work. It is different from you drawing with two battery.
I meant to say I created it in SPICE and I did use two 9 V supplies. Afterward I changed the circuit as little as possible to work off of one supply. See attached.
Took me a few, LOL. You DO need two batteries, give this a try.
Fish
  • Multisim schematic of a 741 op-amp circuit with V1 and V2 9 V supplies, R1 47kΩ, R4 100kΩ, R3 10kΩ, C1 100nF, and an oscilloscope XSC1 showing a square wave trace.
With respect, the initial diagram tells you that you need a + and - supply. The input biasing is taken to the Earth point, which is half way between the two supplies. How could anyone be surprised that the circuit didn't work when connected 'lop sided'? These devices have pretty good common mode rejection but give 'em a chance!
This circuit works well in practice, but it does depend on the output either being positive or negative and a simulator can start up with the output being zero.
I tried this recently and had to deliberately unbalance the circuit by adding a large value resistor from one of the supply rails to the non inverting input.
[PLAIN]http://dl.dropbox.com/u/4222062/square%20wave%20oscillator.PNG
thanks for all the feed back. I would like my final product to have a pot to vary the frequency and one to vary the amplitude. Would i just preplace one of the resistors with a pot to make the freq vary? Also for amplitude would i just wire in a pot before the output?
First try the extra resistor shown in the previous post to see if you get oscillation.
If you do, then R1 and C control the frequency so it is easiest to make R1 variable.
The voltage at the non inverting input sets the amplitude of the square wave, however adjusting it may cause loss of oscillation.
You could just put a pot (maybe 10 K) from the output of the opamp to ground and take the output from the moving contact and ground. Try simulating it.
ugh i must suck at simulating. My result was a flat line on the oscillospope
I also noticed its a LM124 op amp. I only have a 741
here is my schemtaics for the simulation
Grey warning triangle icon with an exclamation mark, indicating an error or alert message rather than circuit content.
I get delays of a second or so before it starts oscillating.
Can you set your time so that you watch it for 5 seconds?
The actual opamp probably doesn't matter for this simulation.
Hmm i started at the oscope for like a minute and it was a flat line
  • Screenshot of the Oscilloscope-XSC1 simulator window showing a black grid display with a flat orange trace along the bottom left, readouts reading 0.000 V on Channel A and Channel B, timebase set to 1 s/Div and Channel A and B scales at 5 V/Div.
omonoid,
I mean no disrespect, but I downloaded multisim, leaned it and made it work in 2 hours using your OP schematic. I posted the screen shot. Exactly how are you having difficulty with the notion the 741 requires a dual polarity supply when it was part of your OP? Anyway, I hope you get your EC; I did my part for fun, LOL.
Fish
Fish yours was helplful and worked fine...its the only success I've had. I was just trying to get the schematics vk6kro put up working.
Fish is there a way of reconfiguring yours to only have 1 9v? when i actually build it i don't want to have 2 batteries
Also i threw in a 10k pot in place of your R4 so i can adjust the frequency and it works.
Is there a way of calculating for the right size pot to use? i want it to be able to go from around 100 HZ to 2.5 MHz. The built in oscope doesn't show frequency
I think I am going to stick with Fish's schematic beacuse its the only one working. Thanks! everyone who offered advice
omonoid,
The 741 REQUIRES a dual polarity supply the way you are using it. You could supply it from a voltage divider, but I would give that design a "zero". If you are looking for "extra credit", earn it, LOL, understand the chip. Take heart in this notion: I have a degree in English Literature, Electronics is just a hobby for me :-) I do thank you for introducing me to multisim, it is very cool!
Fish
There is no reason any of the opamps should require a dual supply. In fact you should be able to accomplish this with an inverting Schmidt Trigger gate.
One reason your circuit may not be oscillating, or that it takes so long to begin oscillating, is that MultiSim likes to start the simulation with a quiescent voltage applied to the capacitor. Have you tried bringing up the capacitor and setting the initial condition (IC) to zero volts?
I tried your circuit of post #16 and it worked fine. However, in your schematic I don't see any power source for the opamp. If you can replace that opamp with the uA741 in the first post and connect pin 4 to ground and 7 to +9V, does it work?
Of course that's true but, if you use a single power supply, your biasing has to be modified accordingly. The amplifier amplifies the Difference between - and + inputs so they need to be more or less equal, if the gain is 10,000X. Notice that the 'working' version (above) has its + input biased to half rail volts, which allows it to work with one power supply.
Edit. In the original circuit, if using a single PSU, when the -input goes up, the output will go down and the +input can remain below -input, even when the capacitor has stabilised - you're relying on the op amp functioning properly with inputs right next to the ground and -in can still be higher than +in (not being properly defined). The idea is to operate an op amp with its inputs around half rail so that either can be made higher or lower than the other, in a well defined way.
I tried incorperating a voltage divider on a 9v so i would have a + and - 4.5v going to the opamp. For some reason the oscope displayed a odd shaped non square wave. What am i doing wrong?
  • Multisim schematic of a 741 op-amp oscillator with R3 47kΩ feedback, C1 100nF, R1 and R2 10kΩ potentiometers, R4 10kΩ potentiometer, and a 9V supply with R5 and R6 1kΩ divider; oscilloscope XSC1 trace shows a distorted sawtooth-like waveform, not a square wave.
