Trying to wrap my brain around entanglement-superposition
  • Context: Graduate
  • Thread starter Thread starter drschools
    Brain
The discussion revolves around the concept of entangled superposition in quantum mechanics, exploring analogies to classical probability and the nature of measurement. Participants examine the differences between classical and quantum states, particularly in the context of entanglement and superposition.
  • One participant proposes an analogy between entangled superposition and a multiple choice question, suggesting that the state of the answers exists in superposition until an observer selects an answer, which then defines the state of the other options.
  • Another participant argues that the analogy presented is more aligned with classical probability theory, explaining that quantum mechanics allows for pure states to change upon observation, unlike classical states which remain fixed.
  • This participant provides an example using a dice throw to illustrate the difference between mixed states in classical probability and the behavior of quantum states in measurements, particularly referencing the Stern-Gerlach experiment.
  • A later reply emphasizes that there is no classical analogue of entanglement, cautioning against drawing parallels between quantum mechanics and classical concepts, as such analogies can be misleading.
Participants express differing views on the appropriateness of analogies between classical and quantum systems, with some supporting the use of analogies for understanding and others cautioning against them. The discussion remains unresolved regarding the validity of the initial analogy and the implications of quantum measurement.
Participants highlight limitations in understanding quantum mechanics through classical frameworks, noting that key concepts like entanglement do not have direct classical counterparts. The discussion reflects varying interpretations of measurement and state changes in quantum systems.
drschools
Could entangled superposition be something like the state of a mutiple choice question where 1)there are two or more options for answers (...the nature of a multiple choice question:approve:) before an answer is chosen by the observer-test taker and 2) the state of the question once the observer/test-taker answers the question. Before the question is answered the answers are in a kind of superposition - possibilities with accompanying probability. Once answered, the results take on a their differentiated "entangled" state... the one answer "chosen" determines the state of the other options - "not chosen". In binary quantum terms, "chosen" =1 , "not chosen" =0.
In this way the test taker (observer) defines the identity of the answers rather than the designer of the question...i.e. the focus of the answer is on which answer is chosen, not the content of the answer or even if it is right or wrong.
What think thee?
What you are describing is classical probability theory. The possible outcomes are the answers to questions and are called pure states. When the outcome could be a randomly selected pure state that is called a mixed state - that is the questions before an answer is selected. QM is different - the pure states themselves can give different pure states as outcomes if observed (this is called a superposition) - classical probability theory can't do this. If you have a pure state - then that's it - you can't observe it to get another pure state. Every time you observe it you get exactly the same pure state.
Here is an example. Before you throw a dice the outcome is the number 1 to 6 with a probability of 1/6th. That's a mixed state. Throw it and you get 1 to 6. Let's say you get 1. Doesn't matter what you do unless you throw the dice again it will be 1 when you observe it.
Now let's look at QM and see what happens in the famed Stern-Gerlach experiment:
http://en.wikipedia.org/wiki/Stern–Gerlach_experiment
We measure the spin in say the x direction and you get two possible values - called spin up and spin down - suppose it's up. Its in a pure state whose x direction of spin is up. Measure it again and you get the same value - fine. This is exactly the same as the dice situation - sweet. Now measure the the spin in another direction say y and you again get two values - up or down. Say its up so its in a pure state in the y direction of up. Great. But now measure the spin in the x direction - if it was like classical probability theory you should get up. But that's not what happens - you do not get the same value - sometimes its up and sometimes its down. Somehow measuring it in a different direction caused the value in the first direction to change. This is not like your answering question analogy. It would be like you answered question 1 then answered question 2 and somehow that changed the answer to question 1. Pure states do not remain 'fixed' like in classical probability theory.
QM also has mixed states - which are randomly selected pure states - but it has the added feature observations can change pure states into other pure states.
Check out:
http://arxiv.org/pdf/quant-ph/0101012v4.pdf
http://arxiv.org/pdf/0911.0695v1.pdf
Thanks
Bill
I appreciate the feedback and references Bill. I'm hungry to learn more, so you gave me more to chew on.
Thanks
Dave
Just to underline Bill's point a bit: there is no classical analogue of entanglement. I know it's helpful when learning someone to try to draw analogies between what you're studying and what you already know, but such analogies are very precarious in quantum mechanics. Some of the key ideas in QM, like entanglement, aren't like anything else you're already familiar with. So, the answer to, "Is entanglement like X?" (where X is some everyday thing) is always going to be no.
  • · Replies 58 ·
  • · Replies 178 ·
10K
  • · Replies 20 ·
  • · Replies 19 ·
10K
