spdowind
- Messages
- 8
- Reaction score
- 0
Two blocks are on a frictionless track with a vertical, quarter circle, and 30 degree incline. Released from rest at point A, 1 kg smaller block 1 slides to B and makes an inelastic collision with 5 kg stationary larger block 2. The collision sents block 2 up the ramp. The smaller block slides back up along the track after collision reach highest point C. If angle locates point C is 60 degrees, find max distance "s" block 2 travel on the incline.
[PLAIN]http://img704.imageshack.us/img704/752/picturefv.jpg
Energy equation : K1+ Ug1+ UE1+Work= K2+Ug2+UE2
Inelastic collision equation: m1v1+ m2v2= m1v1' + m2v2'
1. I found the velocity for slider 1 BEFORE collision using energy equation.
2. I then use the inelastic collision equation and found V'1(at B) + 5V'2(at B) = 7.668. Which is the equation for velocity of slider 1 and 2 at point B after they collide.
3. Then I used energy equation again for B to C motion by slider 1 AFTER collision. I found V'1( at B) = 14.7. I plug this in the step 2 result and found V'2 (at B), which is the velocity of slider 2 at Point B AFTER collision.
4. Then I used energy equation for motion B to D for slider 2 AFTER collision. D being furthest part on the incline slider 2 travels on. Here I find "s" being 0.202 meters.
However, the answer is 0.54 meters, I am not sure what I am doing wrong, I doubled checked my steps and my calculations, too.
Hopefully someone could help, thanks!
