Two blocks sliding and the collision
The discussion revolves around a physics problem involving two blocks on a frictionless track, where a 1 kg block (Block 1) collides inelastically with a stationary 5 kg block (Block 2) on a 30-degree incline. The calculations utilize the energy conservation equation and the inelastic collision equation to determine the maximum distance "s" that Block 2 travels up the incline. The correct answer for "s" is established as 0.54 meters, with critical corrections made regarding the velocity calculations, specifically ensuring that the velocity of Block 1 is treated as negative due to its direction.
  • Understanding of energy conservation principles in physics
  • Familiarity with inelastic collision equations
  • Knowledge of kinematics and motion on inclined planes
  • Ability to perform calculations involving square roots and negative values
  • Review the principles of energy conservation in mechanical systems
  • Study inelastic collision dynamics and their applications
  • Learn about motion on inclined planes and the effects of angles on distance traveled
  • Practice solving similar physics problems involving multiple objects and collisions
Students studying physics, particularly those preparing for exams involving mechanics, collision theory, and energy conservation principles.
spdowind
Two blocks are on a frictionless track with a vertical, quarter circle, and 30 degree incline. Released from rest at point A, 1 kg smaller block 1 slides to B and makes an inelastic collision with 5 kg stationary larger block 2. The collision sents block 2 up the ramp. The smaller block slides back up along the track after collision reach highest point C. If angle locates point C is 60 degrees, find max distance "s" block 2 travel on the incline.
[PLAIN]http://img704.imageshack.us/img704/752/picturefv.jpg
Energy equation : K1+ Ug1+ UE1+Work= K2+Ug2+UE2
Inelastic collision equation: m1v1+ m2v2= m1v1' + m2v2'
1. I found the velocity for slider 1 BEFORE collision using energy equation.
2. I then use the inelastic collision equation and found V'1(at B) + 5V'2(at B) = 7.668. Which is the equation for velocity of slider 1 and 2 at point B after they collide.
3. Then I used energy equation again for B to C motion by slider 1 AFTER collision. I found V'1( at B) = 14.7. I plug this in the step 2 result and found V'2 (at B), which is the velocity of slider 2 at Point B AFTER collision.
4. Then I used energy equation for motion B to D for slider 2 AFTER collision. D being furthest part on the incline slider 2 travels on. Here I find "s" being 0.202 meters.
However, the answer is 0.54 meters, I am not sure what I am doing wrong, I doubled checked my steps and my calculations, too.
Hopefully someone could help, thanks!
I tried the question and I get 0.54m as well. Exactly actually. I think your mistake is here "V'1( at B) = 14.7". I get sqrt(1.5g) = 3.834. Did you forget to square root it here? Also, don't forget V1 should be plugged in as negative since it's moving to the left.
I tried it again with cleaner procedures and found that it should be sqrt 14.7. However, I forgot to make V1 negative this time. Good thing I checked this and with your help I changed V1 to negative and guess what, I finally found the correct answer.
Thank you so much! This was the only one I'm stuck on for my test tomorrow and now I am all set!
  • · Replies 18 ·
