Two loudspeakers, an oscillator and constructive interference at a point?
To determine the frequency that produces constructive interference at point P from two loudspeakers, the distances from each loudspeaker to point P must be equal to an integer multiple of the wavelength. The speed of sound is given as 344 m/s, and the frequency range of the oscillator is between 1300 Hz and 1800 Hz. The relationship between speed, frequency, and wavelength can be used to formulate the necessary equations. By calculating the wavelengths corresponding to the desired frequencies, one can find the conditions for constructive interference. Understanding these principles is essential for solving the problem effectively.
Cade
Two loudspeakers placed X meters apart are driven in phase by an audio oscillator, whose frequency
range is 1300 Hz to 1800 Hz. A point P is located A meters from one loudspeaker and B meters from the
other. The speed of sound is 344 m/s. What is the frequency produced by the oscillator, for which
constructive interference of sound occurs at point P?
I don't know how to start.
For constructive interference, the distance from the two sources to P must be an equal number of wavelengths. Writing that as an equation would give you a start!
