Two nested solenoids and their magnetic fields
The discussion centers on calculating the electromotive force (emf) generated by two nested solenoids using Faraday's law of electromagnetic induction. Participants emphasize the necessity of applying the derivative of current (I) with respect to time (t) and using the equation ##\displaystyle{d(BA)\over dt}## to determine the emf as a function of time. The assumption that the magnetic field B1 remains constant over the length of the small coil is also confirmed as valid for this calculation.
  • Understanding of Faraday's law of electromagnetic induction
  • Knowledge of solenoid magnetic fields and their properties
  • Familiarity with calculus, specifically derivatives
  • Basic concepts of electromotive force (emf)
  • Study the application of Faraday's law in different electromagnetic scenarios
  • Explore the concept of inductance in electrical circuits
  • Learn about the behavior of magnetic fields in nested solenoids
  • Investigate the mathematical derivation of emf in varying magnetic fields
Physics students, electrical engineers, and anyone interested in the principles of electromagnetism and solenoid applications.
MahalMuh
We have 2 solenoids. The smaller (2) is inside the large one (1) with the axes aligned. Length1 is 0.63, radius1 0.051 m and N1 670 turns. The smaller length2 0.23 m, radius2 0.031 m and N2 260 turns. The larger solenoid has sine form AC with amplitude of I1 1.51 A and frequency1 120 1/s.
a) What is the biggest magnetic field B1 of the larger solenoid?
b) How large is the highest voltage V2 of the smaller solenoid?
B1 = u0*N1*I1 / length1
Several forms for M, inductance
I = I0 * sin(frequency*t)
Faradays's law for V =
a) is pretty clear and got correct but b) I'm struggling with.
For b) I guess one could take the derivative of I and specify the moment t when you can plug that into Faraday's law. Or could this be solved somehow with inductance?
Hi,
You didn't write down Faraday's law, but that is indeed what you need.
Faraday's law needs ##\displaystyle{d(BA)\over dt}## and you have all you need to calculate the generated emf, which then comes out as a function of time.
(I am fairly certain you are allowed to use B1 as if it's constant over the length of the small coil).
  • · Replies 16 ·
