Two nonconducting spheres problem
  • Thread starter Thread starter n77ler
    Spheres
The problem involves two nonconducting spheres with a total charge of 13.4 μC and a repulsive force of 2.777 N when separated by 0.362 m. The correct equations to use are Coulomb's law, F = k(q1)(q2)/r^2, and the total charge equation, q1 + q2 = 13.4 μC. A user attempted to solve for the charges but encountered issues with the equations, particularly with a typo in the total charge equation. After deriving a quadratic equation, they found potential values for q2 but still did not arrive at the correct answer, indicating a misunderstanding in the application of the equations. Clarification on the equations and their correct usage is needed to resolve the issue.
n77ler
Two nonconducting spheres have a total charge of 13.4 μC. When placed 0.362 m apart. the force of repulsion is 2.777 N. What is the value of the greater charge (Give your answer in coulombs)?
Hint: Coulomb's law.
I tried this equation below because I just put in the total charge for Q and got the wrong answer. I don't understand how I get answers for two different charge swhen I work through it.
E= k (q1+q2) / r^2
well first equation is F = K(q1)(q2)/r^2 and second equation is q1q2=13.4 μC
2 equations 2 unknowns.
You are correct, but that second equation has a typo: it should be q1 + q2 = 13.4 μC
F=kq1q2 / r^2 q1 + q2 = 13.4x10^-6C
2.777= (8.99x10^9)q1q2 /(0.362)^2
q1q2=4.05x10^-11
q1=(4.05x10^-11)/ q2
(4.05x10^-11)/q2 + q2 = 13.4x10^-6C
(4.05x10^-11)/ q2 + (q2^2)/q2 = 13.4x10^-6C
(4.05x10^-11) + (q2^2) = (13.4x10^-6C)q2
quadratic, when solved q2=4.60x10^-6, q2= 8.80x10^-6
Both of these numbers when added up will equal the total charge and when I sub them into the equation q1=(4.05x10^-11)/q2 I get the same thing. However this is not the correct answer, could someone point out where I went wrong?
