I Two Observers Moving Opposite Dir Rel to Each Other
  • I
  • Thread starter Thread starter Sang-Hyeon Han
    Relative
Sang-Hyeon Han
Hello guys. I have a question for one of postulates of relativity. Consider there are three observers (called A, B, and C) in x-direction only. A is at rest. B is moving to the left relative to A with velocity 0.7c. C is to the right relative to A with velocity 0.7c. Then when A sees B or C, they can not move faster than c. It's correct right? However, when B and C see each other, is it possible that their (relative) velocities are faster than c (maybe 1.4c) or not?
No. When B and C look at each other, they will see the other moving away at a speed grater than 0.7c but less than c. It will be about 0.94c.
Likes Sang-Hyeon Han
How can we get that value??
Using the 'relativistic velocity addition' formula:
245387
You will find that, no matter what values you use for the two spaceships, the receding velocity will not exceed c.
eg: If you set v=-0.7c and u' as 0.7c, the result will be 0.94c.
Note: this is not just for relativistic velocities. It will give accurate results at any speed (even stoned koala speed) it's just at - at anything less than relativistic velocities - the denominator becomes one plus (nearly) zero and we get the common v+u' velocity we know and love.
Ahh I understand. many thanks guys!
The relative speed of two objects is the speed of one object in the rest frame of the other object. It's best to work with manifestly covariant objects. In this case these are the proper four-velocities, which are in your case
$$u_A=\begin{pmatrix} 1 \\ 0 \\ 0 \\ 0 \end{pmatrix}, \quad u_B=\frac{1}{\sqrt{1-0.7^2}} \begin{pmatrix}1 \\ -0.7 \\ 0 \\ 0 \end{pmatrix}, \quad u_C=\frac{1}{\sqrt{1-0.7^2}} \begin{pmatrix}1 \\ 0.7 \\ 0 \\ 0 \end{pmatrix}.$$
Now you don't need a Lorentz transformation to get the relative speed of each observer since you can get this with Minkowski products between these four-velocities.
For observer A, at rest in the computational frame, it's easy to see that you get the time-component of the four-velocities of B and C just by the Minkowski product of their four-velocities with ##u_A##:
$$(\gamma_B)_A =u_A \cdot u_B=\frac{1}{\sqrt{1-0.7^2}}.$$
This is the ##\gamma## factor of B measured by A who is at rest in the computational frame. From the ##\gamma## factor you get back ##\beta=|\vec{\beta}|=|\vec{v}/c|## simply by
$$(\beta_B)_A=\sqrt{1-\frac{1}{(\gamma_B)_A^2}}=0.7.$$
That's trivial, but the magic of covariant treatments is that since it's working with invariants, it's a general valid formula, i.e., to get the speed of ##B## as measured by ##C## you simply calculate the ##\gamma## factor of ##B## as measured by ##C## via the Minkowski product of the four-velocities,
$$(\gamma_B)_C=u_C \cdot u_B=\frac{1}{1-0.7^2}(1+0.7^2)=149/51$$
and thus the relative speed
$$(\beta_B)_C=\sqrt{1-1/(\gamma_B)_C^2} \simeq 0.940.$$
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
