Is there a formula for combining heat capacities of liquids and gases?
The discussion revolves around the combination of heat capacities for liquids and gases, specifically focusing on water, oil, and natural gas. The original poster seeks a formula to effectively combine these heat capacities in a multi-phase system.
  • Mixed
  • Participants explore the independence of heat capacity contributions from different phases and question the implications of phase changes on heat capacity calculations.
Several participants have provided insights on calculating heat capacities, discussing the importance of mass flow rates and the definitions of variables involved. There is ongoing exploration of different approaches to arrive at a meaningful expression for the system's heat capacity.
Participants are considering the effects of phase changes, such as vaporization, and the need for consistent units when calculating heat capacities in a non-homogeneous mixture.
Howy
Hi,
I was woindering if anyone can help me on a problem I have been stuck on for a while now.
I have an equation to combine the heat capcity of oil and water, but I can't find an equation anywhere that combines the heat capacities for water oil and gas.
All i have is CpL = (qo(qo+qw))Cpo+(1-(qo/(qo+qw))Cpw
Does anyone know a formula for combing heat capacity of liquids and gases
Thanks, Howy
Hi Howy, welcome to PF. This equation should work well for liquid-gas combinations too. It's simply saying the heat capacity contributions are independent and combined according to the (atomic) fraction of each material.
For a two-phase solution of water and steam, say at 100 degrees C, the heat capacity should include the heat of vaporization.
Bob S
Ah, good catch. I was assuming no phase change (which would apply to oil, water, and air around room temperature). Including a phase change, the heat capacity could be infinite for a solution combining a liquid with its own vapor (at constant pressure), for example. Howy, can you tell us what the gas is?
Wow,
Thanks for the hasty reply guys. Probably best to assume the following:
Water (pure)
Oil with a SG of 0.88 and a Cp of 1.7585 kj/kg.K
Gas (natural) with a Sg of 0.7 and a Cp of 5.5265 kj/kg.K
OK, for this particular system at thermal equilibrium, I don't see a problem with calculating the mass of each component and multiplying it by the material's specific heat capacity, and summing the results to estimate the system's heat capacity.
so do you think the following is acceptable?
Cp = (qo/qt)Cpo + (qw/qt)Cpw +(qg/qt)Cpg
What are the definition and units of the q's?
qo = quantity of oil being added
qw = quantity of water being added
qg = quantity of gas being added
qt = quantity of mixture
providing units are all the same i would have thought the units aren't important as it just a ratio
OK, thanks for the clarification on definitions. This equation is going to give you a specific heat capacity, which isn't really meaningful, since the system isn't homogeneous. (For example, a sample random kilogram might contain all oil, all water, a mixture also containing some gas, etc.) It would be better to multiply the mass of each component by that material's specific heat capacity, then sum the results to obtain the system heat capacity (in J/K). Does this make sense?
My understanding is, first work out each phase's mass flow rate
Wo = (densityofoil*qo)
Ww = (densityofwate*qw)
Wg = (densityofgas*qg)
WTotal = Wo + Ww + Wg
Then work out the ratio,
CpTotal = (Wo/WTotal)*Cpo + (Ww/WTotal)*Cpw + (Wg/WTotal)*Cpg
