Ultrasonic Sensor Setup for Distance Detection
  • Thread starter Thread starter electricalcoolness
    Sensors Ultrasonic
Ultrasonic sensors can be effectively used for distance detection by connecting them in a circuit that applies voltage to the transmitter and measures the response. New users are encouraged to explore resources that explain circuit integration and sensor operation principles. Sound waves at 40kHz can partially penetrate walls, but higher frequencies generally reflect more, depending on material density. For surface detection, a simple pulse can be used, while detecting embedded objects requires a coded pulse for time-resolved returns. Properly overdriving the transmitter can enhance range, provided the power limits in the specifications are adhered to.
electricalcoolness
I have a question regarding ultrasonic sensors. Let's say for example I want to use a typical ultrasonic sensor, in this case let's say: http://www.jameco.com/webapp/wcs/st...toreId=10001&catalogId=10001&productId=136653
in a circuit for distance detection. How would I hook it up for use?
Or if someone could direct me to a resource or something that could help me understand how to place these things in circuits.
Im fairly new to the sensor area in EE. Do I apply a voltage on one end, and expect as response voltage on the other? Thanks in advance guys.
Many thanks on the links, now perhaps a physicist can enlighten me, can the sounds waves at 40KHZ on a range sensor penetrate walls if operating within operational range? Or would the sound waves always be bounced off walls or windows and not get through to the other side?
A proportion will reflect and a proportion will penetrate each density boundary. In general the higher the frequency the greater the reflection, but it is very material dependent.
If you want to just detect surfaces then use a plain pulse and detect the first return.
If you want to detect embedded objects or inclusions then use a coded pulse and detect each return time resolved through a matched filter. By estimating the speed of sound through the material you can calculate the depth of the density boundary.
Another advantage of pulse encryption is that you can seriously overdrive the TX transducer getting much improved range, providing you follow the power derating curves in the spec sheet.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
