Ultraviolet Catastrophe / Rayleigh-Jeans Black Body Cavity
mrjeffy321
In reading about the “Ultraviolet Catastrophe” in dealing with black body radiation, my book says that at the ultraviolet frequencies and beyond, the Rayleigh-Jean equation for the energy density of the radiation would be infinite (and thus a catastrophe).
If this is the Rayleign-Jeans equation:
p(v)dv = (8 * pi * v^2 * k * T * dv) / c^3
with v being the frequency of light…how does this number come out to be infinite at some finite frequency?
For example, 1 E16 Hz would be well within the ultraviolet part of the EM spectrum. If I plug this value into the above equation I will get a very large number to be sure, but it will not be infinity. Or do they just mean that as the frequency goes to infinity, so does the energy, when we know otherwise experimentally.
Objects don't radiate at a single frequency only. The problem is the total energy that you get when you integrate over all frequencies. In the classical Rayleigh-Jeans analysis, there's no upper limit on the frequency.
Correct, and its ironic in fact that quantum mechanics was given birth by the observation that you had to cut the divergence off in just about the most naive way imaginable to a theorist. So Planck basically curve fitted and found that the only way to do this was by adding an arbitrary h in integer units to the equation.
No one until Bohr believed for a second this adhoc curve fitting had anything to do with reality, except that it was a convenient semi empirical law, good for handwavey arguments. And then, even then, his model was quite obviously flawed so it took an extra 10 years (and many experiments) before people took it seriously and QM became accepted lore.
OK, I see. Thanks.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Thread 'Lesser Green's function'
The lesser Green's function is defined as: $$G^{<}(t,t')=i\langle C_{\nu}^{\dagger}(t')C_{\nu}(t)\rangle=i\bra{n}C_{\nu}^{\dagger}(t')C_{\nu}(t)\ket{n}$$ where ##\ket{n}## is the many particle ground state. $$G^{<}(t,t')=i\bra{n}e^{iHt'}C_{\nu}^{\dagger}(0)e^{-iHt'}e^{iHt}C_{\nu}(0)e^{-iHt}\ket{n}$$ First consider the case t <t' Define, $$\ket{\alpha}=e^{-iH(t'-t)}C_{\nu}(0)e^{-iHt}\ket{n}$$ $$\ket{\beta}=C_{\nu}(0)e^{-iHt'}\ket{n}$$ $$G^{<}(t,t')=i\bra{\beta}\ket{\alpha}$$ ##\ket{\alpha}##...
