Unbounded Seq.: 3 is an Upper Bound
  • Thread starter Thread starter fishturtle1
    Sequence
16 replies · 3K views
fishturtle1
Either give an example or show that no example exists.
An unbounded sequence for which 3 is an upper bound, and no β < 3 is an upper bound.
example: {k}3k=-∞
and by this notation i mean that k starts at -∞ and ends at 3, and k∈ℤ .
I chose -∞ as the lower bound because I wanted this sequence to be unbounded. Then I chose 3 as the upper bound because that is what the original statement asked for. My questions:
Does this example fulfill the original statement because I am unsure of what the question means by "and no β < 3 is an upper bound." The book uses β as the upper bound in previous pages.
Also does the way I wrote the sequence mean what I want it to mean? Because I am also confused on the notation.
How can an unbounded sequence have an upper bound?
fishturtle1 said:
example: {k}3k=-∞
Can you list the first, say, five terms in this sequence?
I chose -∞ as the lower bound because I wanted this sequence to be unbounded. Then I chose 3 as the upper bound because that is what the original statement asked for.My questions:
example: {k}3k=-∞
Perhaps an "unbounded sequence" means what everybody else calls an "infinite sequence". An infinite sequence can be bounded or unbounded.
example: {k}3k=-∞
If you mean what I think you do, a better way to write it would be ##a_k = 4-k,~k = 1 ..\infty##.
This is the definition of an unbounded sequence I've been using from online,
a sequence is bounded if it is bounded above and below <=> if ∃k∈ℝ such that | xn | ≤ k ∀n∈ℕ.The first five terms in this sequence would be
-∞, -∞+1, -∞+2, -∞+3, -∞+4I was thinking that an unbounded sequence can have an upper bound if it goes to infinity in some direction but converges to a number as well.
I checked the answer in the back of the book, and the answer is fn=3-n which seems similar to ak=4-k, k=1...∞.
I think I would have gotten this same answer had the original statement been " An unbounded sequence for which 3 is an upper bound ".
I'm still confused by the bold part: "An unbounded sequence for which 3 is an upper bound, and no β < 3 is an upper bound. "
I think that it means no number less than 3 can be an upper bound, but isn't this redundant since we said 3 is an upper bound in the first part of the statement?
No, these aren't numbers.
They are the same, assuming ##n## starts at ##0## in ##3-n##.
No, it isn't redundant. Since ##3## is a term of the sequence, no number ##x## less than ##3## can be an upper bound. How could it be if ##x < 3##?
This sequence is bounded since all of the terms are less than or equal to 3.
I think the problem is poorly worded.
LCKurtz said:
They are the same, assuming ##n## starts at ##0## in ##3-n##.No, it isn't redundant. Since ##3## is a term of the sequence, no number ##x## less than ##3## can be an upper bound. How could it be if ##x < 3##?
Ok I think I get it. So we're told 3 is an upper bound. That means that the greatest number in this sequence is less than or equal to 3.
we're also told that no number less than 3 is an upper bound.
Therefore 3 must be included in this sequence.
If we were not told that no number less than 3 is an upper bound, then our sequence could have been something like xn=-10-n, n=0 . . ∞
Am i understanding this correctly?
Mark44 said:
I don't think so. The definition of bounded sequence I am using is that it is a sequence that is bounded above and bounded below. That is, for some M > 0, |an| < M for all n in Z+ (or similar restriction on n).
See https://proofwiki.org/wiki/Definition:Bounded_Sequence
Then why do you say in post #9 that ##a_k = 4-k,~k=1..\infty## is bounded?
Yes, almost. You could have it true if the sequence just got arbitrarily close to ##3## but less than ##3##.
Ok, thank you both for your help, helped me a lot on this question .
