Understanding the Uncertainty Principle and Quantum Tunneling
  • Thread starter Thread starter r-dizzel
r-dizzel
uncertain about this??
evenin' all!
wonder if anyone can help...
the question is this-
(sorry by the way if this is wrong place to post this, bit of a newbee!)
an electron has 100eV of kinetic energy, its incident on a potential barrier of height 110eV. At what distance x does the probability of finding the electron fall to 1/e of its value at x = 0? compare this with what might of be expeceted from Heisenbergs uncertainty principle.
ive calculated the wavefunctions in and before the boundary but don't really understand what the questions asks "falls to 1/e of its original value"? surely e on its own is meaningless?
the final part about the Heisenbergs unc princ i get but i thought i'd complete the questions.
would really appreciate any help
over and out
r dizzel
You'll probably get a better response if you show more of your work explicitly (i.e. the wavefunctions you've calculated). Anyway, presumably you've matched the two wavefunction amplitudes such that they are continuous across the boundary? Then just find the amplitude ratio so that the new amplitude is
e^-^1 = \frac{1}{e^1} = \frac{1}{2.718...}
of the initial value.
cheers dude, will have a bash
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
