- #1
mohamen
- 8
- 0
wat is under root - i ?
please anser this
please anser this
I personally like Hurkyl's suggestion best but WHY don't you think deMoivre's formula will work? It can be used to find any root of any complex number.mohamen said:will it be solved by the de mouvies theorm...i don't think so...
Under Root - I is a mathematical operation that finds the value of a number or expression that, when multiplied by itself, results in the specified number or expression. It is also known as the square root.
To find the square root of a number, you can use a calculator or manually calculate it using methods such as long division or the Babylonian method. It is also possible to estimate the square root by finding perfect squares that are close to the given number.
Under Root - I finds the square root of a number while Under Root - II finds the cube root, which is the number or expression that, when multiplied by itself three times, results in the specified number or expression.
The symbol for Under Root - I is √, which is called the radical symbol.
Under Root - I is used in various fields such as engineering, physics, and finance. It can be used to find the side length of a square or to calculate the amount of interest on a loan. It is also used in computer programming to calculate square roots of numbers.
