Understanding 132kV Transformer Incomer CTs and Their Core Numbers
  • Thread starter Thread starter khanpk
    Numbers Rating
The discussion revolves around the configuration of 132kV transformer incomer current transformers (CTs) with a specification of 900-600-300/1-1-1-1-1A and a total of five cores. Participants question whether this indicates a single CT package or multiple separate CTs. There is a suggestion that reaching out to the original source of the information could provide clarity on the topic. The conversation emphasizes the importance of understanding the technical details for proper application. Engaging with the author of the paper is considered a potentially intelligent approach for deeper insights.
khanpk
what is meaning of this ?
132kV Transformer INCOMER CTs
(900-600-300/1-1-1-1-1A)
NUMBER OF CORES - 5
is it single CTs package or different CTs ?
Would it be intelligent to ask the person that offers that paper ?
this is copied from internet for learning purpose .
Yes, I know where You found that. For details would it be intelligent to ask the person who put that on the internet for whatever reason ?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
