Understanding AC Emitter Resistance | 25mV
  • Thread starter Thread starter shayaan_musta
    Ac Resistance
4 replies · 12K views
shayaan_musta
Hello experts!
AC emitter resistance is given as,
rE'=25mV/iE
My question is that what does this 25mV tells us? and where does it come from?
Thanks in advance.
Vt = 25 mV is a thermal voltage at room temperature, about 20 degrees Celsius I believe. This value changes with temperature.
It comes from semiconductor physics where you try to describe a PN junctions diode, you arrive at Shockley's equation which describes its IV characteristics. It turns that the Shockley's equation is highly non-linear.
BJT transistors are composed of two such diodes which also behave non-linearly. So ultimately, when you try to describe the behavior of BJT transistor amplifier, it will be non-linear. But because it's difficult to deal with non-linear equations, the diode equations have been linearized by making some assumptions into what is called the small-signal model. As a results a couple of new parameters come into play, such as r_e, r_pi, g_m.
When you work this out, Vt makes its way into the linearized model and that's why see it.
For more info check out: Sedra/Smith.
Thanks for reply.
You mean it is thermal voltage at room temperature and it varies if temperature varies. Am I right?
It is the voltage assumed on 20°C? Am I right?
shayaan_musta said:
Thanks for reply.
Thermal voltage temperature is at 300 K, so that is about 27°C (room temperature)
Bassalisk said:
Thermal temperature is at 300 K, so that is about 27°C (room temperature)
OK. Thanks a lot. :approve:
