Understanding Body Diagonals of a Cube
  • Thread starter Thread starter Disar
    Body Cube
Body diagonals of a cube connect opposite vertices, and the angle between them is 90 degrees as they bisect each other. Users are trying to calculate the angle between these diagonals using vector representations but are struggling with the correct endpoints and calculations. There is confusion regarding the application of the dot product to find the angle, with some users providing incorrect vectors. One user mentions guidance from a professor, suggesting vectors A and B for the diagonals but seeks further clarification on how to apply this. Overall, the discussion highlights challenges in visualizing and calculating angles related to cube body diagonals.
Disar
Can anyone out there tell me what the body diagonals of a cube are.
I am asked to find the angle between the body diagonals of a cube. Seeing as how it is just the application of the dot product it does not seem difficult other than I do not know what body diagonals are (I have an idea but would like to know from someone for sure).
Found it! The body diagonals of a cube are the from one point on a cube to the next and the angle between them is 90 degrees (they bisect one another)
Should of looked first
I have the same problem, yet, I still can't picture it.
slice the cube through the intersecting diagonal... the shape that is left is like an "incline plane". or imagine a table with square top, and square sides and square base with the legs intersecting.
It's the thing in these pictures:
http://library.thinkquest.org/22494/images/cubi.jpg
http://www.mathaware.org/mam/00/master/essays/B3D/2/JPG/figure16.jpg
In the second picture, it's the "longer diagonal".
I seem to be getting an answer of 45 degrees which isn't right...
When drawing the vectors in the case within the cube, do they have to be from the same origin?
nvm, thanks for your help~!
Did you get the correct answer?
i used a unit cube.
with one diagonal at (0 0 1) (1 1 0)
the other diagonal at (0 0 0) (1 1 1)
but it doesn't work, hmmm...for a sec i thought i did get it.
overseastar said:
i used a unit cube.
Good, now find the vectors describing the diagonals using the vectors given above, representing their end-points.
What do you mean by "it doesn't work"? What doesn't work?
The answer written by Disar is incorrect.
oh, if that's the case, I think I got it LOL Thanks a bunch!
I went to my professor about this problem and he told me to use A=x+y+z and B= -x+y+z, naming one of the body diagonals A, and the other body diagonal B. I'm a bit confused how to take the 4 points above to make them fit the A and B my prof gave me. Can anyone help me with this please?? Thanks
Can you help me? I still don't get it, thanks
