Understanding EM Wave Equations
  • Level: Undergrad
  • Thread starter quietrain
    Em Em wave Wave
19 replies · 4K views · last reply
quietrain
hi, i have a problem understanding why the wave equations are as such
if wave is moving left, it is
f(z,t) = Acos(kz + wt - d)
if wave moving right ,
f(z,t) = Acos(-kz -wt + d)
finally i don't know what this represent
f(z,t) = Acos(kz - wt + d)
where A is constant ,
k is wave number,
z is the direction of propgation of wave
w is angular frequency
t is time
d is phase constant
in particular, i have trouble visualizing why if wave is moving right, we + d? and vice versa, left means -d? and what's the 3rd equation? general one?
thanks!
hi quietrain! :wink:
the direction the wave is moving means the direction a particular part of the wave is moving, eg a particular peak of the wave …
a particular peak (or any part) has a fixed value of cos …
and if you fix cos, then you must fix kz + wt,
ie kz + wt = constant, or z = -(w/k + constant/k)t, which is to the left :smile:
that has kz - wt = constant, or z = (w/k + constant/k)t, which is to the right
cos(-x) = cos(x), so that's the same as f(z,t) = Acos(kz + wt - d) :wink:
i can't visualize it :(
but basically, i just make the argument of cos 0? by letting z assume some value to achieve that? (but why do i want to make the argument 0?)
so if my z ends up with -ve, then its to the left? if its +ve then its to the right?
this reminds me of an earlier post i made about the delta dirac function where someone told me i don't have to visualize whether the graph is shifting left or right, all i needed to do was to make the argument of the delta function 0.
ah i found it, its by homology
homology said:
In both cases the delta function is zero unless x=ax-a is a shift right by a, and a-x=-x+a is a reflection of the x-axis and then a shift left (which means a shift right). But just try to see it this way, the integral is zero unless the argument of the delta function is zero. That happens when (above) x=a. But notice that:
[tex] <br /> \int_{\mathbb{R}}f(x)\delta(x+a)dx=f(-a)<br /> [/tex]
I can do that without thinking about how the function's been shifted but rather just seeing where the delta function is equal to zero. Its the same in 3D. When is [tex]\vec{r}-\vec{r'}=\vec{0}[/tex] same time that [tex]\vec{r'}-\vec{r}=\vec{0}[/tex]
cos 0 is just a convient point to track, it is the peak. [itex]\omega t - kz[/itex] is the connection between time and displacement. By making [itex](\omega t - kz)[/itex]= constant, you can track the point on the sine wave moving as time change.
For example, if t increase, in order for [itex]\omega t - kz[/itex] = constant, z has to increase, that show the wave is traveling forward ( to the right ). If it is [itex]( \omega t + kz)[/itex], then if t increase, z has to go in the negative direction in order to keep [itex]\omega t + kz[/itex]= constant.
All it is that it is easiest to use the peak as the reference point so [itex]\omega t - kz[/itex] = 0 where [itex]cos(\omega t - kz) = 0[/itex].
[itex]cos( -\omega t + kz)[/itex] is really using in math only. We usually use [itex]cos( \omega t -kz) \;\hbox { which is the }\; \Re[e^{j(\omega t - kz)}][/itex] in phasor form study more commonly used in engineering electromagnetics for transmission lines. But that is a totally different big topic that electrodynamics don't have to deal with ( consider yourself lucky!)
i went to think about it ,
for example we have a line x = 1
if now i do a x-5, then wouldn't it be x = -4 now.
so x-5 shifts the graph to the left?
so why is it when kz - wt, it shifts to the right?
yungman said:
cos 0 is just a convient point to track, it is the peak. [itex]\omega t - kz[/itex] is the connection between time and displacement. But making [itex](\omega t - kz)[/itex]= constant, you can track the point on the sine wave moving as time change.
For example, if t increase, in order for [itex]\omega t - kz[/itex] = constant, z has to increase, that show the wave is traveling forward ( to the right ). If it is [itex]\omega t + kz[/itex], then if t increase, z has to go in the negative direction in order to keep [itex]\omega t + kz[/itex]= constant.
wow i learn something new again
so basically i just need to see how t and z is related in the equation?
t always increases right? so if z is +ve, wave moves right
if z is -ve, wave moves left?
but now comes the problem , how do i take into account the phase constant?
do i just include it in the z to make the argument of cos = 0 like in tim's post?
but now, what does a +ve or -ve phase constant tell me? my textbook says its a "delay"?
THat's what I was trying to explain. You normally set up +ve z towards the right.
yes.
Just move forward or backward a constant amount. It is just an offset.
Phase constant is considered as just an offset. The idea is the same. So you look at [itex](\omega t -kz + \phi)[/itex] = constant and you see the phase constant just kind of move the point back or forward by a constant amount.
Takes me a while to figure this out, and it is just that simple!
oh so in this case, since t increase, z has to increase for constant, so it is moving right right?
so if phase constant is +ve, means shift right ? -ve means shift left?
so if question says out of phase by 90degrees, means i plus 90 or minus 90?
I believe so. It is confusing also. +ve means phase lead. It will take less time to reach a point on the positive z direction...like you have a head start with a lead.
Just say out of phase in not enough, because it can be lead or lag 90 deg. +90 is leading by 90 degree, -90 is lagging by 90 deg.
This is my understanding, someone might want to double check.
common sense tells me that +90 is leading too and vice versa...
but after how i see the wave equations is like, common sense doesn't seem right :(
+90 is lead is quoted straight from the book, not my interpretation.
Think of it this way, let t=0 so the peak at [itex](-kz+\phi)=0[/itex]. So if \phi is +ve, the peak is at +ve z location.
ah i see .. i guess common sense was right after all thanks!
I think common sense still work, just takes a lot of effort to develope the "common sense" in this field. I am no expert, I am struggling myself. I responed in more detail in the other post. It just take time to acquire the "common sense". Buy more used books, they all present the material a little different. I have 8 books on this subject! Whenever I don't understand one thing, right away I hit the second and the third book and see whether I get a better explanation.
wow... 8 bookS?
thats amazing...
I am a self studier, I need all the help I can get. If you go to school, you have your professor to go to, I don't! Right now I am stuck on an equation for two days and can't move on, maybe you can help.
oh the ones with the many equations one? i died when i saw the string of equations :(
anyway, i may be in sch , but i realize not all profs are good teachers :(
Yes, that's the one!
