Understanding Force / Pressure Equation
  • Context: Engineering
  • Thread starter Thread starter tomtomtom1
    Force Pressure
The discussion revolves around understanding the pressure equation in the context of calculating the total force acting on a wall due to water pressure. Participants explore the differences between calculating force in one dimension versus across an area, as well as the implications of units and dimensions in these calculations.
  • One participant expresses confusion about the pressure equation and its application to calculating total force on a wall, questioning the difference between one-dimensional and two-dimensional force calculations.
  • Several participants challenge the dimensional correctness of the pressure value given, suggesting it may be misrepresented as Pascals instead of Newtons per meter or another appropriate unit.
  • There is a discussion about the meaning of "per unit length" in the context of the equation, with some participants clarifying that it refers to force per unit width of the wall.
  • A participant provides a worked example to illustrate how to interpret the force per unit width and how it can be scaled based on the actual width of the wall.
  • Another participant seeks clarification on the relationship between two different equations for calculating force acting on submerged objects, leading to a discussion about the equivalence of these equations under certain conditions.
  • One participant elaborates on the derivation of the force equation for a rectangular wall and connects it to the centroid of the wall's area.
  • There is an inquiry about applying similar principles to different shapes, such as triangles and semicircles, in calculating the force acting on submerged objects.
Participants generally agree on the need to clarify the units and dimensions involved in the pressure equation, but multiple competing views remain regarding the interpretation of "per unit length" and the application of the equations to different geometries.
Some participants note limitations in understanding due to ambiguous terminology and the need for clearer definitions of terms like "width" versus "length" in the context of force calculations.
This discussion may be useful for students and practitioners in physics and engineering who are grappling with fluid mechanics concepts, particularly in relation to pressure and force calculations on submerged surfaces.
tomtomtom1
Understanding the Force / Pressure Equation along a wall and across a surface area
p = density * gravity * Distance from the water surface.
Hello all
I am trying to understand the pressure equation.
I have the following question:-
I understand this, to me what this says to me is the total force acting on the wall as a result of the water of 12m is 706320 Pascals.This is where I get a little confused, I have the following question:-
Now I am asked to calculate the total force on a surface area of a wall and because of this I have been told to use a difference equation which involves w i.e. the width.
Am I correct in thinking that the reason why the equations are different is because the first question is only asking me to find the total force in 1 dimension whereas the second question I am asked to find the force across an area which is in 2 dimensions
Is this correct?
Thank you.
Can't be: check the dimensions. Perhaps somewhere it is said 'per meter', or 'the width is 1 meter' ?
If not, then the first picture is simply wrong. Second is correct.
The dimension pascal is wrong in both pictures. In the first one, it should be Newton per meter (or the less meaningful pascal-meter) and in the second one, it should be Newton (which is the unit of force).
Hi Jack
Thank you for your response.
The equation for question one states per unit length but I am not sure what them means?
As for the units, I go that wrong I did the calculation again to get the following:-
1000 * 9.81 * (12^2)/2 = 706320
kg * m * m^2 / m^3 * s^2 = kg/s^2
706320 kg/s^2 - not sure what these units are?
BvU
You mean kg * m * m^2 / (m^3 * s^2) ...
kg/s^2 which can also be written as (kg m/s2)/m or: Newton per meter (see also: #3)
(implict advice: use the sub/superscript buttons)​
So you (they) found the force per unit length (or rather: per unit width)
BvU said:
Second is correct
was put right by @jack action : Not Pa but N
That is right. Since BvU answered this, I will provide an example of how this is used in an effort to clarify for you.
The force you calculated is Newtons per meter. This means Newtons per unit width. Since we are not given the width, your solution is as much as can be given. It is used like this. If the wall is one meter wide, the force on the wall is:
##7036320 \left[\frac{kg}{s^2}\right] 1\left[m\right] = 7036320 \left[\frac{kg m}{s^2}\right] = 7036320 \left[N\right]##
If the wall is 2 meters wide, then the force on the wall is:
##7036320 \left[\frac{kg}{s^2}\right] 2\left[m\right] = 1412640 \left[\frac{kg m}{s^2}\right] = 1412640 \left[N\right]##
HTH
Mfig
Thank you for the worked example.
What you have said makes sense because you have assumed the wall to be one meter wide - that along has cleared things up.
However, looking at the screen shot below:-
The equation I was trying to understand was the one circled in Red - as you can see that there is no mention of the wall width just the comment that states "..per unit length".
This is the confusing part.
tomtomtom1 said:
Mfig
Right. They leave that as an unknown. So you are to find the force per unit width. That is what you did! That is why the units look like they do, and why we can find the total force if we ever find out the width (as my examples showed). They are just saying length instead of width, but it is the same thing as far as the physics goes. Perhaps they mean the area of the wall is length*height whereas I am saying the area is length*width or height*width. That part is just English, not physics.
Mfig
It has started to hit home.
Stepping back for one moment; I can therefore interpret this equation as saying as saying:-
For every 1m of wall width with a height of Y, the total force acting on the wall is F.
Looking at the equation like this along with your worked example makes sense to me now.
Hi mfig
My apologies for bring this thread back to life but something has come up and I was hoping you clarify , as I did not want to create a new post.
I thought that to calculate the total force acting on a wall caused by a fluid in this case water is:-
Where:-
p = density
g = gravity
w = width of wall
Y = height of the water on the wall
However I have since been given the following equation which is meant to tell me the force acting on a submerged object:-
Where
F = Force
p = density
g = gravity
yc = Distance from water surface to the centroid of the submerged object
I am really struggling to understand the difference between the two equations and I was hoping you could or anyone else could shed some light.
Thanks .
Look carefully at your first equation. It applies to a rectangular wall with area A=wy.
##F = \rho g w \frac{y^2}{2} = \rho g w y \frac{y}{2} = \rho g A \frac{y}{2} = \rho g A y_c##
They are the same equation, it is just that the depth of the centroid of a rectangular wall with one edge at the surface is given by half the wall height.
mfig
= p*g*w*(y^2/2)
= p*g*w*y*y*1/2
= Since w*y the same as area I can state:-
= p*g*Area*y*1/2
= Since y*1/2 is the same as y/2 I can state:-
= p*g*Area*y/2
= Since y/2 = the distance from the centroid it is the same as yc giving me:-
Force = p*g*Area*yc.
You are BRILLANT BRILLANT BRILLANT BRILLANT BRILLANT, thank you.
Hi mfig
I wanted to consolidate my understanding what you have showed me.
If I had a triangle submerged underwater and I wanted to find the force acting on one side then would the following be correct:-
I guess I wanted to confirm that Yc is always the distance from the water surface to the objects centroid, in this case my object is a right triangle, to find the centroid of a right triangle I would divide the height by 3 and the breath by 3.
If my submerged object was a semi circle then to find the centroid in the Y dimension it would be 4r/3Pie, I would the force on a semi circle would be 1000 * 9.81 * (14-4r/3Pie).
Would this be correct?
Thanks
  • · Replies 40 ·
  • · Replies 21 ·
