Understanding Generators: How to Predict Performance Before Building
The discussion focuses on predicting generator performance by understanding the relationships between permanent magnet strength, rotation speed, and wire resistance. It highlights that voltage can be calculated using the formula V=-ABwsin(wt), where A represents the area of the loop, B is the magnetic field strength, and w is the angular frequency. Participants clarify that while theoretical calculations can provide insights, practical measurements are often necessary to determine actual performance. There is an acknowledgment of the complexity involved for those new to electric physics. Overall, the conversation emphasizes the importance of understanding these fundamental concepts for accurate generator performance predictions.
Rusty69
I was thinking if the strenght of the permanet magnet could be parallel to I , the rate at which the the magnet (or wire) rotates parallel to V & of course the wire resistance would go with R . If there is some type of way to determine the outcome of a generator before building it, starting it up etc could someone please tell me ? Also am aware the generator would most likely need to be turned on to determine the rate of it's rotation.
Are you asking what the voltage would be based on how fast your rotating your motor in a magnetic field . Voltage is the time derivative of magnetic flux, and the flux would be
ABcos(wt) where A is the cross sectional area of your loop rotating in the B field and
w is the angular frequency of the motor.
so V=-ABwsin(wt)
If that's what your getting at .
Well yes that is what am asking, but am also new to electric physics stuff. Based on that as of now I don't really get what you mean but thank's for posting .
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
