Understanding Helmholtz Coils in CGS Units
The discussion focuses on calculating the magnetic field on the z-axis due to two Helmholtz coils carrying the same current. The derived formula for the magnetic field incorporates the distance from the coils and the radius of the coils. It is clarified that all odd derivatives of the magnetic field at the origin are zero due to the symmetry of the coils, which makes the magnetic field an even function of z. This symmetry results in the first derivative being zero at the origin, as the field reaches a minimum there. The conversation emphasizes the distinction between even and odd functions in relation to their behavior at the origin.
stunner5000pt
Working in CGS units... hence i don't know if my answer is right or wrong anymore... It doesn't 'look' right
Two coils are placed at l and -l on the Z axis as in the figure. They both carry a current I in the same direction (anticlockwise). Both have a radius of a. (Setup like Helmholtz coils.)
a. What is the field on the z axis due to the two coils?
b. Why are all the odd derivatives of B at the origin equal to zero?
Due to the loop of current the field a hieght z above the center of the loop is given by
B = \frac{2\pi Ia^2}{c(a^2 + z^2)^{3/2}}
a) The field is given by B = \frac{2\pi Ia^2}{c}\left( \frac{1}{(R^2 + (z + l)^2)^{3/2}} + \frac{1}{(R^2 + (z - l)^2)^{3/2}} \right)
b) I know that the first derivative of the B field is zero becuase there are no magnetic monopoles. But how does that explain why the octopole moment and so forth are zero? I need some kind of hint so if you could please advise... that would be awesome
Thank you for your help
A lot of B fields have first derivatives.
It is wrong to refer to "octupole moments" for the field between the loops.
Odd derivatives at z=0 are zero, because B is an even function of z due to the symmetry of the coils.
ok so even functions have odd first derivative and even second derivative odd third derivative and so on. But how does that explain that the odd derivative is zero at the origin? Aren't evne functions symmetric wrt reflection on the Y axis? Why aren't even functions zero at the origin?
Mathematically, the derivative of z^(2n) is zero at z=0 for all positive integer n.
Physically, we know the field at the origin is a minimum (it is strongest at +/-L), and is even about the origin. Therefore the tangent is zero.
An odd function must equal zero at the origin because f(0)=-f(0) for an odd function.
An even function needn't be zero because f(0)=f(0) for an even function.
For instance 2+z^2=2 at the origin.
thanks for the help
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
