Understanding Nuclear Stability: The Role of Binding Energy
The discussion revolves around the concept of nuclear stability and binding energy, specifically focusing on Beryllium-8 and its decay processes. Participants explore the relationship between binding energy and stability, questioning the implications of positive binding energy in the context of nuclear decay.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants discuss the definition and implications of binding energy, questioning the textbook's terminology and its application to nuclear stability. There is exploration of how binding energy relates to the stability of decay products compared to the original nucleus.
The discussion is active, with participants providing insights into the definitions of binding energy and mass-energy considerations. Some participants express confusion over the terminology used in the textbook, while others clarify the relationship between binding energy and nuclear stability.
There are references to specific equations and models, such as the semi-empirical mass formula and the liquid drop model, which are mentioned as relevant to understanding the stability of even-even versus odd-odd nuclei. Participants note the importance of distinguishing between binding energy and mass-energy differences in decay processes.
Mark Zhu
See Attachment
See Attachment
This is an example from my textbook that I am having trouble understanding. So the binding energy of Beryllium-8 is positive 56.6 MeV, so it means the nuclide is stable, right? My textbook seems to use the reference of positive binding energy as being stable. And so that means alpha decay for Beryllium-8 is unfavorable, because that binding energy is negative. Then why does the textbook say, "From the standpoint of energy, there is no reason why a 8Be nucleus will not decay into two alpha particles" and that Beryllium-8 is unstable, yet it has a positive binding energy? Thank you.
I don't think they should really be using the term 'binding energy' to refer to the difference in energy of the products and reactions of the decay [they ought to use mass/energy defect, or similar], since binding energy refers specifically to how much energy you need to supply to separate the system into its individual parts.
Anyway, what they're saying is that the two helium nuclei produced by the decay have a lower combined rest mass than the original nucleus, i.e. it's an energetically favourable process for the decay to proceed in the forward direction [i.e. "unstable w.r.t. ##\text{He}##"]. The 'lost' energy becomes kinetic in the decay products.
Mark Zhu said:
Okay, so given that definition of binding energy, higher binding energy = more stable nucleus.
Yes, a nucleus with a higher binding energy per nucleon is generally more energetically stable with respect to its constituent protons and neutrons.
Mark Zhu said:
If so, then wouldn't a loss in the net binding energy in the decay mean the product (two alpha particles) has lower binding energy than 8Be and is thus less stable than the 8Be?
You're confusing what binding energy means, and that's probably the fault of the author's bad wording. If you have a nucleus of some variety, the binding energy is the amount of energy you need to supply to separate it into its constituent protons and neutrons, at infinity.
The two helium nuclei produced have a lower combined mass, and thus a lower combined energy, but that means they have a higher binding energy [i.e. you need to put in more energy to separate the nucleons!]. That means, they're more stable.
If we are talking in terms of mass in mass-energy, then that makes sense. Because later there is another equation later introduced in the attachment below, and in that equation, the last term delta is positive for even-even nuclei and negative for odd-odd nuclei. As even-even nuclei are more stable, then higher binding energy = more stable.
Edit: sorry forgot to add the attachment.
Yes, the attachment is the so-called 'liquid drop model (or if you want to be fancy, 'semi-empirical mass formula') approximation.
Yes. The semi-empirical liquid drop model. Thank you for your help. I understand it now. I confused change in energy with binding energy.
  • · Replies 16 ·
