Understanding Optical Tunneling
  • Thread starter Thread starter cragar
    Optical Tunneling
Optical tunneling is demonstrated through the interaction of microwaves with wax prisms, where a signal is lost when a single prism is used but restored with a second prism placed nearby. This phenomenon suggests that photons can transfer between prisms without traversing the space in between, relying on evanescent wave coupling. The introduction of a sheet metal barrier disrupts this tunneling effect, confirming that the metal blocks the evanescent field necessary for signal transmission. The discussion highlights the concepts of frustrated total internal reflection and the role of evanescent fields in optical tunneling. Understanding these principles is crucial for grasping the behavior of photons in such experimental setups.
cragar
So i was messing around with a wax prism and a microwave emitter. So I have an emitter and a detector and the microwaves are being shot straight across to the detector. But when I place a Wax prism in between it stops getting the signal . But then when we place a second wax prism next to it, it starts to get the signal again. And we placed the second prism from the side that was receiving no microwaves. Then i placed a piece of sheet metal between them and it stopped getting the signal. But it was explained to me that the photons went from one prism to the other without ever being in the gap. So it shouldn't matter that i put a piece of metal in between the prisms. Or are the microwaves getting redirected by the second prism?
Science news on Phys.org
Check out "frustrated total internal reflection" and "evanescent wave coupling". That should help you get oriented- there are no propagating photons in the gap, but there is an evanescent field. The piece of metal will indeed prevent tunneling,
ok thanks for your response
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
