Are Significant Figures Really That Important?
  • Thread starter Thread starter nobahar
Significant figures are often misunderstood, leading to confusion about their importance in calculations. The discussion highlights that while performing operations like multiplication, the precision of the result can be influenced by the uncertainty in the original numbers. For example, multiplying 2.09 and 3.52 yields 7.36, but the last digit may not be reliable due to potential unknowns in the input values. The conversation also illustrates that even if one variable is known to three significant figures, the derived variable can have much less certainty, as shown in the equation y=1/(2-x). This emphasizes that significant figures should not be taken lightly, as they can misrepresent the accuracy of calculations.
nobahar
Hello!
I've used significant figures without really thinking about them too much; and I have never really understood there use.
I found this thread: https://www.physicsforums.com/showthread.php?t=477786&highlight=significant+figures
Where it has been argued that they should be 'taken lightly', so to speak.
Here's where I have always been confused, and I hope someone can help!:
If I were to perform the multiplication, 2.09*3.52, I have three significant figures in both numbers, and so the answer would be 7.36 (from 7.3568).
I think this example shows one issue, and that is that the 6 is not necessarily 'known'.
Indeed, depending on the numbers in the multiplication, digits in higher powers of ten columns can be affected by 'unknown' numbers in smaller powers of ten columns. So when a number is given to x significant figures, these numbers may not be the actual numbers!, since they can be influenced by unknown numbers of smaller magnitudes of ten e.g. 1/10th column, 1/100th column, etc can affect the value in the 100 column or the 101 column, etc.
So when I see some calculation using significant figures, I should not necessarily believe any of the numbers are absolutely certain?
I hope that makes sense!
Thanks in advance.
if we say x=1.97, then it is taken as being between 1.96 and 1.98
consider the equation, y=1/(2-x)
If x=1.96, then y=25
if x=1.98, then y=50
so, we have found, y=37 +/- 13
Summarizing, although x was known to 3 sig figs, y is known to not much better than 1 sig fig.
Does this illustrate what you were talking about?
Yes, but clearly the problem step was (2-x), which left you with 0.03, known to one sig fig. The OP's example had only multiplication, which tends to be less tricky.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
15K
