Understanding the Integral of e^x: When is it Equal to xe^x?
  • Thread starter Thread starter robertjford80
    E^x Integral
19 replies · 6K views
robertjford80
I thought sometimes the integral of e^x is xe^x. Under what circumstances is the integral of e^x = xe^x? I think it has something to do with u substitution.
on Phys.org
Under NO circumstances is the integral of e^x equal to x e^x. I cannot imagine why you think that would hold.
RGV
what about the derivative?
The derivative of [itex]e^x[/itex] is: [tex]e^x .\frac{d(x)}{dx}[/tex]
The derivative of [itex]xe^x[/itex] is, by the product rule [itex](x)'e^x+ (x)(e^x)'= 1(e^x)+ x(e^x)= xe^x+ e^x= (x+ 1)e^x[/itex]. As Ray Vickson said, the integral of [itex]xe^x[/itex] is NOT equal to itself and neither is the derivative.
The only functions having the property that their derivative is equal to the function itself is a constant times [itex]e^x[/itex].
I don't think anyone could have explained it better. This should resolve your confusion, robertjford80.
Here's an example
What's going on here? It clear says that the derivative of
c1e(3/2)x[ = (3/2)c1e(3/2)x
so the integral of e^2x is e^2x and the derivative of e^x is e^x but the derivative of e^2x is 2e^2x, is that right?
Correct, except for the integral of ##e^{2x}## which is ##\frac{e^{2x}}{2}##
well, why don't you use the chain rule with e^x which would make it xe^x?
{this referred to number nine's deleted post} i saw it before he deleted it.
The chain rule is to multiply by the derivative, and the derivative of x is 1.
If it helps, d/dx (ex) = 1 * ex
thanks villyer, I hadn't thought about that.
No, the first statement is not right, and is not what you asked originally. The indefinite integral of exp(a*x) for constant a is (1/a)*exp(a*x) + C; the derivative of exp(a*x) is a*exp(a*x). When a = 1 these both give just exp(x). For a = 2 they give (1/2) exp(2x) and 2 exp(2x), respectively.
RGV
That's exactly what i said before.
if you're talking about post 4, then i don't think you provided enough info to convey that
It's obvious that [itex]\frac{dx}{dx}=1[/itex] which gives [itex]e^x .1=e^x[/itex]. Unless, you didn't know that, but it's really a basic notion of the principles of differentiation.
You should go over the basic principles, as it should help you to understand ##e^x## and the others more complicated that will follow.
if it was obvious i would not have posted the question
d(ex)/dx = ex
And so
∫ex dx = ___________ ...(i)
Note that integration is just reverse of differentiation.
If you want to verify this , then its simple ! Differentiate the left hand side of equation (i) with respect to x and see if its equal to ex. It will work.
If you want to prove it then analyze it by means of graph of f(x)=ex.
And note if you do this :
d(ex)/d(e) = xex-1
But it can never be xex !
