Understanding the Raman Spectra of Metals
Pure metals do not exhibit Raman peaks primarily because they are highly polarizable, making it difficult for atomic vibrations to induce a change in polarizability necessary for Raman activity. Visible light cannot penetrate metals effectively, which contributes to this lack of Raman scattering. However, it is suggested that small clusters of metal atoms or thin films may show some Raman activity. The discussion also raises the possibility of using ultraviolet light, which can penetrate metals above their plasma frequency, to observe Raman peaks in metallic structures. The comparison with materials like diamond and graphene, which do have Raman peaks, highlights the differences in atomic arrangements and polarizability behavior between metals and these non-metallic materials.
jrobin
Hi all,
I'm just wondering why pure metals, whatever kinds, do not have Raman peaks. Because the visible light cannot penetrate the metals? If so, what kind of EM wave can penetrate metals? Just need some key words for further information. Of course, I would appreciate if you would explain more for me. Thank you!
Chemistry news on Phys.org
jrobin said:
Hi all,
In order for a species to be Raman active, it must have vibrations (or rotations) that result in a change in the polarizability of the molecule or material. Since metals are infinitely polarizable (to a good approximation), it is hard to see how a vibration of the atoms in the crystal lattice could cause a change in the polarizability. Of course this description is only approximate ... it may be that small clusters of metal atoms, or perhaps even thin films, do show Raman activity to some extent.
I am not certain that this explanation is completely accurate, but I do think it is qualitatively correct with respect to your question.
First of all, thank you so much SpectraCat for the kind discussion.
I was thinking of it in the similar way in the first place, however, it kind of confused me when I saw that diamond and graphene (all composed by "atom" with specific orientations in crystal) actually have Raman peaks.
Would it be possible that it's because the visible light actually is hard to penetrate the metals?
I would guess that you can observe Raman peaks in metals using UV light above the plasma frequency.
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
