Understanding the Role of Friction in Car Wheels Turning
The discussion revolves around the role of friction in the context of car wheels turning, exploring how different types of friction interact with the motion of the vehicle. Participants examine the implications of static and dynamic friction, particularly in relation to driven and non-driven wheels, and the effects of these forces on the car's movement.
  • Some participants propose that when a car moves forward, the friction on the wheel acts in the direction of travel, which seems contradictory to the notion that friction always opposes motion.
  • One participant questions the direction of the tire's contact patch movement relative to the road surface when traction is lost.
  • Another participant clarifies that the bottom of the wheel moves backward while the friction on the ground acts toward the front of the car.
  • Some participants assert that static friction between the wheel and the road acts in the direction of travel for driven wheels, while dynamic friction between the wheel and the car acts in the opposite direction.
  • There is a discussion about whether non-driven wheels experience static friction with the road, with some participants suggesting they do, but in the opposite direction compared to driven wheels.
  • Participants explore the concept of axle friction and its role in the overall dynamics of the car, noting that it counteracts the driving force.
  • One participant suggests neglecting internal friction to simplify the discussion, focusing instead on the external forces acting on the car.
  • There is a consideration of how static friction is necessary for changing the rotational speed of non-driven wheels, while constant wheel speed implies no friction.
Participants express differing views on the nature and effects of friction in relation to driven and non-driven wheels, indicating that multiple competing perspectives remain without a clear consensus.
Limitations in the discussion include assumptions about neglecting internal friction and the simplification of the car's motion to a straight path, which may not fully capture the complexities of real-world scenarios.
Michhcim
When a car moves forward, the wheel turns it exerts a force on the road in the opposite direction of travel, and friction counter acts it. the wheel turns and the car moves forward This implies that friction on the wheel is acting in the direction of the car moving. Though I thought that friction always acts in the opposite direction of travel?
Imagine that you applied enough power to lose traction and spin the wheels. Which direction is the tire's contact patch moving, relative to the road surface?
The bottom of the wheel is moving back, toward the back of the car (assuming the car in not in reverse!). The friction on the ground acts opposite to that, toward the front of the car.
I think i can answer my own question, the static friction between the wheel and the road acts in the direction of travel. The dynamic friction between the wheel and the car acts opposite the direction of travel. This is the friction shown in the free body diagram of a car moving.
Only for the driven wheels (connected to the engine)
What do you mean here. Axle friction?
Does that mean that the non driven wheels, do not experience any static friction with the road?
Point 1 Does that mean that the non driven wheels, do not experience any static friction with the road?
Point 2 Yes, the dynamic friction between all the moving parts, from the engine to the axle. That is countering the driving force of the car
They do, because of axle friction, but in the opposite direction than the driven wheels.
To keep things simple, let's neglect internal friction in the car, e.g., axle friction, and rolling friction. Let's also assume the car is moving on a straight path do we can assume there are no forces causing the direction of the car's motion to change.
If the wheels are speeding up or slowing down, there's static friction between the wheels and the road. It's the friction that supplies the torque needed to change the rotational speed of the non-driven wheels. If the wheels turn at a constant rate, there's no friction.
If you look at the car a single object, these are internal forces that don't affect the overall motion of the car directly. What they do is they tend to slow down the rotation of the wheels. If the tire is not to skid, this torque causing the wheels to slow must be opposed by a torque due to friction between the road and the wheel. That's the external force acting on the car that causes it to slow down.
  • · Replies 29 ·
  • · Replies 73 ·
11K
  • · Replies 52 ·
  • · Replies 45 ·
