Understanding the Single Photon in Double Slit Experiments
In the double slit experiment with photons, individual photons can be fired one at a time to eventually reveal an interference pattern. A single photon is defined by its detection, typically indicated by a "tick" in devices like photomultiplier tubes. Researchers can fire single photons using dim light sources combined with neutral density filters to reduce the photon rate. This method allows for the confirmation of single photon presence by adjusting the filters until only one photon is detected at a time. There are also established techniques for generating single photons on demand, demonstrating that it is indeed possible to control photon emission.
Phymath
when performing a double slit experiment using photons it is said that if you fire individual photons that over time as more photons are fired the interference pattern starts to appear. My question is how do they define a single photon? what is the method that they can fire one photon at a time controllably so? how do they define a photon?
One "tick" in their detector (a photomultiplier tube or something) is a single photon. That's what particle *are*. They are things that come into your detector and go "tick!"
so just to clarify there is no known way to fire a single photon from a source?
Yes, they can fire single photons. That is how they do the experiments you are talking about.
Easiest way is to get a dim light source and then put neutral density filters (welding mask glass is good) in front of it until you are only getting a few photons / sec. You can confirm this by pointing the detector direcly at the source without any sllits.
You can of course add more filters to reduce the rate until you are convinced there is only one photon in the system at once.
There are already many schemes that produce single photon on demand. See, for example
http://physics.nist.gov/Divisions/Div844/facilities/cprad/PhotonSource.htm
Zz.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
