Understanding work done by friction
The discussion centers around the concept of work done by friction, exploring its implications in various scenarios, including pushing a block on a rough surface and walking. Participants examine the definitions of work and energy, particularly in relation to conservative and non-conservative forces, and the potential energy associated with frictional forces.
  • Some participants assert that the work done by friction is negative because the force of friction acts opposite to the displacement.
  • Others argue that friction is not doing work, as the direction of movement is opposite to the force, and that the force overcoming friction is the one doing work.
  • A participant claims that while friction is often considered non-conservative, it can still be viewed as doing work, leading to a rise in temperature and energy within the block.
  • It is noted that the equation dU = -F.dx applies only to conservative forces, and that friction does not store energy in the object but rather converts it to heat energy.
  • Some participants discuss the frame dependence of work done by friction, suggesting that in different frames, the work could be positive, negative, or zero.
  • Questions arise about the work done by friction during walking, with some suggesting it may be zero due to no displacement of the foot, while others clarify that static friction does no work in the ground frame.
  • A more complex view is presented, suggesting that in a thermodynamic context, friction could be treated as a gradient of potential energy, depending on both position and temperature.
Participants express multiple competing views regarding the nature of work done by friction, with no consensus reached on whether friction does work or how to interpret its effects in different scenarios.
There are limitations in the discussion regarding the assumptions made about the nature of forces, the definitions of work and energy, and the conditions under which the equations apply. The discussion also highlights the complexity of analyzing work in non-conservative systems.
hale2bopp
Work done is defined as F vector. dx vector or F dx cos θ where θ is the angle between F vector and dx vector.
But, there is another common formula-
dU=-F.dx
Here, dU is the potential energy stored in the object on which the force is acting upon. (Am I correct?)
But, the work done on the object, gets stored in it as its internal energy (assuming no heat loss).
So.
In the case of pushing a block on a rough floor.
The force of friction acts opposite to displacement in this case, and so work done would be
F(r).dx cos 180 = -F(r).dx, i.e. negative.
But if we look at it from the energy stored formula, the energy stored in the object would be - (-F(r) dx) = F(r)dx., i.e. positive.
How come the two energies, although they represent the same thing, have different signs?
I am sensing that there is something very wrong with my understanding of things.
Help would be appreciated!
Friction isn't doing work (precisely because the direction of movement is opposite to the force). The force overcoming friction is doing work.
in fact friction force is non conservative in common language but it is wrong.when sliding friction is acting as in this case friction will do work and the body will come ultimately to rest but from microscopic point of view the atoms or electrons inside the block will get temp. rise and kinetic theory implies that these will be more energetic(kinetic energy) so it may seem that the kinetic energy of block has been destroyed and turned into heat but it is not so.for further reference see feynman lectures vol. 1.
The equation dU = - F.dx applies only when the force F is a conservative force, like gravity or spring forces. Friction is a nonconservative force, so that equation does not apply here. The work done by friction does not store energy in the object. It adds generally heat energy into the system.
Sure it is. A non-zero force does no work only if the force is normal to the direction of motion.
dU=-F.dx
Friction is a non-conservative force, which means it cannot be expressed as the gradient of a potential function.
In other words, you can't use that formula for friction.
The direction of movement is frame dependent. You can always pick some frame where it has the same direction as the force. In frames where they have opposite directions negative work is done.
Okay. Right, so friction is non conservative and we can only apply this equation in case of conservative forces.
What happens during walking? Will the work done by friction be negative or positive, or zero? I think it will be zero since there is no actual displacement of the foot.
Yes. The ground does no work through static friction on the foot the ground frame. But as I said, in some other frame it might do positive or negative work. Personally I think it is better not to talk about "force X doing work on object A", but "object B doing work on object A through force X"
One should distinguish between work and a potential of a force.
In the general case work is a functional of a particle's trajectory, which is the solution of the particle's equation of motion, including any kind of forces (conservative, non-conservative or dissipative), i.e.,
[tex]W[x,C]=\int_C \mathrm{d} \vec{x} \cdot \vec{F}(t,\vec{x},\dot{\vec{x}}) = \int_{t_1}^{t_2} \mathrm{d}t \dot{\vec{x}}(t) \cdot \vec{F}[t,\vec{x}(t),\dot{\vec{x}}(t)].[/tex]
As I said, here [itex]\vec{x}(t)[/itex] is a solution of the equation of motion.
In the case of a conservative force, the result only depends on the end points of any path in configuration space, leading to a potential for the force, which then is of course only a function of [itex]\vec{x}[/itex], i.e.,
[tex]\vec{F}=\vec{F}(\vec{x})=-\vec{\nabla} V(\vec{x}).[/tex]
Here we have
[tex]V(\vec{x})=-\int_{C(\vec{x}_0,\vec{x})} \mathrm{d} \vec{x}' \cdot \vec{F}(\vec{x}').[/tex]
Here [itex]C(\vec{x}_0,\vec{x})[/itex] is an arbitrary path connecting a fixed point [itex]\vec{x}_0[/itex] with the point [itex]\vec{x}[/itex] (of course one has to apply some caution, if one deals with forces defined in regions that are not simply connected).
There is an alternative view on it: Even in the case of a non-conservative force the force may be the gradient of a potential in a thermodynamical setting.
Consider the idealized situation that the block is thermally insulated from its surrounding and the friction only increases the internal energy U of the block (i.e. that you can neglect the heat capacity of the floor). Then the formula dU=-F dx will hold along any differentiable path and the force is the gradient of the potential energy U. However, U will not only be a function of x but in marked difference to classical mechanics also of temperature T. Or, to put it differently, we would have to specify not only the coordinate x of the path but also the temperature T(x) along the path.
  • · Replies 48 ·
  • · Replies 77 ·
  • · Replies 54 ·
  • · Replies 24 ·
