Understanding X10 Power: Circuit Diagrams and Explanations"
  • Thread starter Thread starter juming
    Power
The discussion centers on the operation of X10 power modules, specifically how they draw DC power from a live circuit in older homes using a loop-in arrangement. Participants highlight that X10 "plug n play" switches can leak a small current through the light fixture, allowing them to function without a direct neutral wire. The conversation also touches on alternative methods for creating an electronic light switch, suggesting the use of motion detector switches for integrated power management circuitry.
  • Understanding of X10 power line communication technology
  • Familiarity with electrical circuit diagrams
  • Knowledge of AC voltage specifications, particularly 120VAC/60Hz
  • Basic electronics skills for building light switches
  • Research X10 power line communication schematics and operation
  • Explore circuit design for electronic light switches
  • Investigate motion detector switch circuitry and components
  • Learn about power management techniques in low-voltage applications
Electronics hobbyists, electrical engineers, and DIY enthusiasts interested in home automation and power line communication technologies.
juming
Hey,
Older homes use a loop-in arrangement where the two wires coming down to a light switch are both live, and the neutral's nowhere near.
The X10 "plug n play" switches leak a small current through the light and draw their current from there... I was just wondering, how exactly do they do this?
Can someone point me in the direction of a full circuit diagram of how the X10 modules draw their DC power inline with the live??
Sorry, man... I have no idea what you're talking about. :confused:
For the pulg in units that something else plugs into. I think there is a fairly standard power arangement.
if you're talking about a replacement wall switch then I think there are two tap methods. One for power off just assumes a low load resistance, the other for power on uses a small inductor.
Don't have any X10 schematics.
Danger: http://en.wikipedia.org/wiki/X10_(industry_standard )
http://www.smarthomeusa.com/info/x10theory/x10theory/#theory
NoTime: I'm basically trying to build an electronic light switch of my own, but I need a DC power source in the light switch, so I'm not after X10 specifically, just the same way they tap their power.
Thanks for the replies :)
Thanks for the links. The Wiki article isn't there, but the other one was about as comprehensive as anyone could want. I used to have the plans around somewhere for an intercom system that transmitted over the power lines, but that was just a straight signal over the system-neutral wire. This thing is in a whole 'nother realm. One question, though; it appears to be specifically tuned for 120VAC/60Hz. Do they make a European version as well?
danger, yeh...
its not specifically tuned... that's just an american website :)
Figures. :rolleyes:
I never got around to analysing how this was done.
But, you could pick up a cheap motion detector switch.
This would have all the power managment circuitry.
Probably cheaper than buying the components seperatly.
  • · Replies 22 ·
  • · Replies 79 ·
12K
  • · Replies 19 ·
  • · Replies 17 ·
