Uniform Circular Motion of a motorcycle
A motorcycle traveling at a constant speed of 25.0 m/s over a hill with a radius of curvature of 126 m has a mass of 342 kg. The centripetal force calculated is 1.70 x 10^3 N, which is confirmed correct. However, there was confusion regarding the normal force, initially calculated as 5048 N, but the correct value is 1.66 x 10^3 N. The normal force is determined by the equation Fn = Fg - Fc, where the centripetal force acts towards the center of the curve. The discussion clarifies the relationship between these forces in uniform circular motion.
ShamTheCandle
A motorcycle has a constant speed of 25.0 m/s as it passes over the top of a hill whose radius of curvature is 126 m. The mass of the motorcycle and driver is 342 kg. Find the magnitude of (a) the centripetal force and (b) the normal force that acts on the cycle.
F(centripetal) = mv^2/r
Weight=mg
Using the formula for centripetal force, I found that the answer for part (a) is 1.70 x 10^3 N. My answer matches with the back of book. So it is right. However, for part (b) I used that
Normal Force = Weight + Centripetal Force = 5048 N. I don't think it is right since the back of the book says the answer is 1.66 x 10^3.
Thank you for helping.
thefifthlord said:
Centripetal force always acts towards the center, in this case the center is up, so its actually
Edit: Sorry typo.
Fn = Fg - Fc
To anyone who is reading this thread, i need major help here: https://www.physicsforums.com/showthread.php?t=356807
Ohhh, I see. This makes sense now. Thank you!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
