Uniform circular motion proportionality question
In the discussion about uniform circular motion, the focus is on how the period of rotation changes when the radius is altered while applying the same force. When the radius is doubled, the new period T2 is derived to be T2 = sqrt(2) * T1, indicating that T2 is approximately 1.414 times longer than the original period T1. Conversely, when the radius is halved, the period T2 is found to be T2 = T1 / sqrt(2), making it about 0.707 times shorter than T1. The mathematical approach involves manipulating the formula for the period in relation to the radius and force. This analysis demonstrates a clear relationship between radius and period in uniform circular motion.
Sean1218
David spins a sling in a horizontal circle above his head. What would happen to the period of rotation if he applied the same force and the length was a) doubled, b) halved
ac = (4π2r) / T2
Just not sure what to do in general, I tried a few different things like this:
r \alpha T2
2r \alpha T2
r \alpha T2/2
Then compared T2 and T2/2
square rooted both of them
T and T/sqrt(2)
1/sqrt(2) is 0.7, which is the answer to b), even though I was trying to do a).
edit: think I figured it out
I can just equate T and T/sqrt(2) can't I? The first T is Ta, the second is Tb, and that equation is saying that Ta is .7x smaller than Tb, in other words, Tb is 1.4x larger, right?
My approach would be to solve the formula for T:
T1 = 2π*sqrt(mR/F)
I wrote that T1 to indicate it is the original period.
When R is doubled, you get
T2 = 2π*sqrt(m2R/F) and I wish I could make that 2R a red 2 to make it easier to follow. That 2 needs to go out of the sqrt where it becomes a root 2 and move to the front so you can see
T2 = sqrt(2)*2π*sqrt(mR/F) = sqrt(2)*T1
It is an excellent technique; works every time!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
