Uniform Convergence and integration
The discussion centers on the implications of uniform convergence of continuous functions on a closed interval and its relationship to integration. It establishes that if the integral of the limit function does not equal the limit of the integrals of the sequence, then the sequence is not uniformly convergent. Participants explore the contrapositive of the theorem, emphasizing the importance of defining statements clearly to avoid confusion. The conversation also touches on the necessity of understanding the assumptions behind the statements to accurately determine their negations. Overall, clarity in defining conditions is crucial for correctly applying the theorem and its contrapositive.
angryfaceofdr
What can I conclude using the following theorem?
Let the functions u_n (x) be continuous on the closed interval a \le x \le b and let them converge uniformly on this interval to the limit function u(x). Then
<br /> \int_a^b u (x) \, dx=\lim_{n \to \infty} \int_a^b u_n (x) \, dx<br />
Can I conclude that if \int_a^b u (x) \, dx \neq \lim_{n \to \infty} \int_a^b u_n (x) \, dx, then the sequence of functions u_n (x) is NOT uniformly convergent on the interval?
-Also what is the contrapositive of the above theorem? (I am confused on how to negate P=" Let the functions u_n (x) be continuous on the closed interval a \le x \le b and let them converge uniformly on this interval to the limit function u(x)." )
If you get confused by logic, then try to assign symbols for different statements, and reduce the problem to a simpler form. If you know
<br /> A\quad\textrm{and}\quad B\implies C<br />
then you also know
<br /> \textrm{not}\; C\implies (\textrm{not}\;A)\quad\textrm{or}\quad(\textrm{not}\;B)<br />
Your example is slightly more confusing than it would need to be, because continuity of u_n is not highly essential. If u_n and u are integrable, and u_n\to u uniformly, then
<br /> \lim_{n\to\infty} \int\limits_a^b u_n(x)dx = \int\limits_a^b u(x) dx.<br />
Substituting A to be the knowledge that u_n are all continuous, B to be the knowledge that u_n\to u uniformly, and C to be the knowledge that the limit and integral commute, might bring some clarity.
I would also set D to be the knowledge that u_n and u are integrable. Then
<br /> B\quad\textrm{and}\quad D\implies C<br />
and
<br /> A\quad\textrm{and}\quad B\implies D<br />
(additional comment: I just realized that if u_n are integrable and if u_n\to u uniformly, then probably u is integrable too, but I'm not 100% sure of this right now. It could be that some parts of my response are not the most sense making, but I think there is nothing incorrect there anyway.)
How would you get \neg A? Do you negate closed and the interval as a&gt;x&gt;b?
Or in other words,
" Assume the functions u_n (x) are not continuous on the not closed interval a &gt; x &gt; b"?
I would keep the assumption that the functions are of form u_n:[a,b]\to\mathbb{C} untouched, and only let A concern the continuity.
It should be recognized that there is true ambiguity in questions like this. If I declare that u_n will always have the domain [a,b], and then state that A means that u_n are all continuous, than \neg A will simply mean that u_n are not all continuous. This is what I meant originally.
Alternatively one could state that A means that u_n all have the domain [a,b] and that u_n are all continuous. Then \neg A would mean that u_n don't all have the domain [a,b] or that u_n are not all continuous.
You must know yourself what you mean by A, before asking what \neg A is.
How does one know when to do this?
My fear is what if I "choose" the wrong statement A like I did in post #3? How would I know what the "right" statement is?
There are no right or wrong choices for A. What matters is that you know what you have chosen.
Once A has been fixed, there can be right or wrong deductions, however.
(There was a movie where somebody said something like "there's no right or wrong decisions. What matters is that you dare to make a decision". It could be this is slightly off topic, though.)
  • · Replies 31 ·
