Uniqueness/existence for FEA with Amontons friction?
  • Thread starter Thread starter bcrowell
    Fea Friction
The discussion centers on a research project involving numerical simulations of knots, specifically determining the lowest coefficient of friction for a square knot to hold under load using finite element analysis (FEA) and the Amontons model of friction. The author questions whether the Amontons model provides a uniquely defined solution for the system, given the complexity of interactions among rope segments. They highlight the challenge of having multiple frictional forces with numerous degrees of freedom, leading to potential underdetermined conditions. The author seeks insights on the existence and uniqueness of motion in this context and wonders about existing software solutions for addressing these challenges. The exploration aims to clarify the application of the Amontons model in practical scenarios involving knot stability.
bcrowell
Staff Emeritus
Insights Author
I'm exploring a possible research project involving numerical simulations of knots. For example, I would like to be able to determine from simulations what is the lowest coefficient of friction for which a square knot holds under load. (Pencil-and-paper calculations by Maddocks and Keller with some approximations give about 0.24, but the approximations are probably not very good.) The idea is to do a finite element analysis (FEA), using the Amontons model of friction (i.e., the model of friction taught in freshman physics).
I'm now trying to sketch out what a physical model would look like, and it's not really obvious to me that the Amontons model gives a uniquely defined answer for this type of system. My idea was to do a very simple FEA in which I break up the rope into short segments (e.g., a straight rope would be a series of disks). A given segment of the rope could be in contact with as many as six other segments. We tell freshman physics students that static friction acts in the direction that tends to prevent slipping, but this seems likely to leave me with an underdetermined system, since we have as many as six frictional forces, each with two unknown components in the plane of contact, for a total of as many as 12 degrees of freedom.
Is there any reason to expect existence and uniqueness of the motion when Amontons friction is used? There are various software packages to do general-purpose FEA, so it seems like there must be some way of handling this issue...?
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
