Unit Conversions of Force: How to Convert Between Different Units of Force?
  • Context: Undergrad
  • Thread starter Thread starter kokofaen
    Force Unit conversion
The discussion revolves around the conversion of force units, specifically converting a force of 100 N expressed in base units of Kg∙m∙(s)^-2 into dg∙cm∙(ms)^−2. Participants explore the reasoning behind the conversion process and clarify the relationships between the various units involved.
  • Homework-related
  • One participant expresses confusion about combining unit conversions despite understanding individual conversions.
  • Another participant points out the need to convert seconds to milliseconds in the context of the problem.
  • There is a question regarding the meaning of "dg" and clarification that it refers to decigrams.
  • A participant suggests using the method of multiplying by terms that are "1" to facilitate unit conversion, providing an example of converting seconds to hours.
  • Clarifications are made regarding the relationships between units: 1 kg = 10,000 dg, 1 m = 100 cm, and 1 s = 1000 ms.
  • A participant questions the reciprocal nature of seconds and milliseconds in the context of Newtons being expressed as S^-2 or ms^-2.
  • There is a mention of the relationship between speed and distance over time, with an example of how 1 m/s translates to millimeters per millisecond.
Participants generally agree on the conversion factors for the units discussed, but there is some uncertainty regarding the application of these conversions in the context of the original problem. The discussion remains unresolved regarding the exact reasoning behind the conversion process and its implications.
Participants have not fully resolved the mathematical steps involved in the conversion process, and there may be assumptions regarding the understanding of unit conversions that are not explicitly stated.
kokofaen
TL;DR
Kg to dg, m to cm and s to ms
Hello.
Im studying for an exam and came across this simple unit conversion question but I haven't done something like this in a long time! I understand the conversions of each unit individually but get a bit stuck combining them. This is the question:
A force of 100 N is exerted on an object with the base units of Kg∙m∙(s)^-2
Express this in dg∙cm∙(ms)^−2
The answer:
100 dg∙cm∙(ms)^−2 = 1.0 x 10^2(dg∙cm∙(ms)^−2)
Could someone please explain why the converted answer is still simply 100 when the units have been converted to different degrees (e.g. 1kg =10,000 dg vs 1m =100cm)? Thank you!
You also have to convert seconds to milliseconds.
Welcome to PF.
What is "dg" as a unit? Degrees? Decigrams? Something else?
Assuming from your equations that dg is decigrams, how many decigrams per kilogram? Remember that when converting units, one of the best ways is to just multiply through by terms that are "1" in value, but have both sets of units (the old ones and the new ones) expressed as a fraction. For example, if you want to convert some number of seconds to hours, you would do this:
$$7200 [seconds] = 7200 [seconds] \times 1 = 7200 [seconds] \frac{1 [hour]}{3600 [seconds]} = 2 [hour]$$
  • Love
Hi, yes thank you for that.
The unit is decigrams.
So based on what you've said, would the working for this equation look like this:
1 kg = 10,000 dg
1 m = 100 cm
1 s = 1000 ms
Also could I clarify that the reason the seconds and milliseconds are the reciprocal of the other units (which have the units converting TO as the numerator and FROM as the denominator) is because the units for newtowns are S^-2 or ms^-2 respectively?
Ĺ
1 kg = 10,000 dg
1 m = 100 cm
1 s = 1000 ms
If a particle moves at ##1m/s##, then that is only ##0.001 m## per millisecond. Or ##1## millimeter per millisecond. ##1 m/s## is certainly not the same as ##1km## per millisecond.
  • · Replies 18 ·
