Undergrad Units of trigonometric functions?
Trigonometric functions like sine and cosine are dimensionless, meaning their outputs do not have units. When calculating values such as Sin(0.5), the result is a pure number derived from the ratio of side lengths in a right triangle. This ratio can be interpreted as a percentage, but it is important to note that percentages are typically understood as values between 0% and 100%. The tangent function, while also a ratio, can yield any real number, which complicates comparisons to percentages. Overall, trigonometric functions are best understood as ratios rather than having specific units of measurement.
John Greger
TL;DR
If I take say Sin(0.5), what would the units of the output be?
What are the units of the trigonometric functions sinus, cosinus etc? If I take say Sin(0.5), what would the units of the output be?
John Greger said:
Summary:: If I take say Sin(0.5), what would the units of the output be?
Why do you think they have any units?
Likes vanhees71
If I have a right angled triangle, what is ##\sin## of one angle in terms of the side lengths? What are the units of that expression?
Likes vanhees71, etotheipi and Dale
In addition to @Ibix's argument, the other common argument comes from looking at the series expansions, e.g. for ##\sin{x}##,$$\sin{x} = \sum_{n=0}^{\infty} u_n = \sum_{n=0}^{\infty} (-1)^n \frac{x^{2n+1}}{(2n+1)!}$$Take any two terms ##u_a## and ##u_b## where ##a \neq b##, then for dimensional homogeneity you require that ##[x]^{2a+1} = [x]^{2b+1}## but this is only satisfied when ##[x] = 1##.
Likes vanhees71 and Ibix
You could consider sines and cosines as percentages or ratios.
It is a comparison between the legths of one side and the hypotenuse.
Please, see:
https://en.m.wikipedia.org/wiki/Percentage
"A percentage is a dimensionless number (pure number); it has no unit of measurement."
Please, see:
Comparing trigonometric functions to percentage might be quite misleading, imho. And not applicable to tangent.
Yes, it is: the tangent is the ratio of the lengths of the two legs (opposite to adjacent).
Likes vanhees71 and Lnewqban
No issue with ratios, in my post I was referring to percentage only. Let me explain more particularly what I meant ..
Tangent returns any value from ##-\infty## to ##\infty##, its codomain is any real number. Although you can define a mapping between real numbers and the typical interval of percentage from 0.0% to 100.0%, I don't see any added value by doing so. I admit, "not applicable" is not the best word I could have used.
For sine and cosine, the analogy with percentage makes little bit more sense, as their return real numbers between -1.0 and 1.0, but I would need to use negative percentage, ie. interval -100.0% to 100.0%.
I realize that theoretically the percentage can take any real number, but typically one think of it as a number between 0% and 100%. That is why I said it might be misleading. Personally I found this kind of analogies more confusing than clarifying.
Likes vanhees71 and PeterDonis
  • · Replies 28 ·
  • · Replies 26 ·
