Universe Age: Why Is There a Set Number?
TheScienceOrca
If this is true, why is there a set number of years that the "universe" has existed for? Aren't different parts of the universe traveling at EXTREMELY different relative speeds? Doesn't this mean that the universe is a different age depending on your location in the universe, which you are of course part of the universe itself.
The numbers usually quoted for the "age" of the universe assume a "comoving" observer, i.e., one who is at rest in the standard cosmological coordinates (alternatively, one to whom the universe looks homogenous and isotropic). An observer who is not comoving would observe a different universe age (i.e., a different elapsed time since the Big Bang, or since some other universe-wide event such as the surface of last scattering of the CMB).
For example, we on Earth are not comoving observers--we observe a significant dipole anisotropy in the CMB (as well as other indications of our motion relative to the average motion of all the galaxies). So the actual proper time elapsed on our Earth worldline since the Big Bang (assuming for the sake of argument that we can extrapolate Earth's worldline back that far) would be a bit smaller than the standard figure quoted for the "age" of the universe, which, as noted above, assumes a comoving observer. The difference would not be very much because Earth is moving very slowly, in relativistic terms, compared to a comoving observer; our velocity is a few hundred km/sec, or about 1/1000 of the speed of light.
Not in the sense that matters for the question you are asking. (Btw, in a recent thread you appeared to believe that objects at rest in cosmological coordinates were "not moving" relative to each other; that makes the question I just quoted above seem rather odd coming from you.)
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
Thread 'Dirac's integral for the energy-momentum of the gravitational field'
See Dirac's brief treatment of the energy-momentum pseudo-tensor in the attached picture. Dirac is presumably integrating eq. (31.2) over the 4D "hypercylinder" defined by ##T_1 \le x^0 \le T_2## and ##\mathbf{|x|} \le R##, where ##R## is sufficiently large to include all the matter-energy fields in the system. Then \begin{align} 0 &= \int_V \left[ ({t_\mu}^\nu + T_\mu^\nu)\sqrt{-g}\, \right]_{,\nu} d^4 x = \int_{\partial V} ({t_\mu}^\nu + T_\mu^\nu)\sqrt{-g} \, dS_\nu \nonumber\\ &= \left(...
Abstract The gravitational-wave signal GW250114 was observed by the two LIGO detectors with a network matched-filter signal-to-noise ratio of 80. The signal was emitted by the coalescence of two black holes with near-equal masses ## m_1=33.6_{-0.8}^{+1.2} M_{⊙} ## and ## m_2=32.2_{-1. 3}^{+0.8} M_{⊙}##, and small spins ##\chi_{1,2}\leq 0.26 ## (90% credibility) and negligible eccentricity ##e⁢\leq 0.03.## Postmerger data excluding the peak region are consistent with the dominant quadrupolar...
