Unorthodox "space" elevator idea
The discussion explores the feasibility of a floating platform supported by hydrogen balloons as an alternative to a traditional space elevator. Proponents suggest that launching from a height of 15-20 miles could reduce energy costs significantly, particularly for the initial ascent. However, critics argue that most fuel is required for achieving horizontal velocity, not just overcoming gravitational pull, making the proposed method less effective than anticipated. Additionally, logistical challenges and the economic viability of producing and maintaining such a platform raise concerns. Overall, while the idea presents an innovative approach, significant doubts exist regarding its practicality and cost-effectiveness.
serp777
Would it be possible, instead of building a 22 thousand mile long space elevator, to make a large floating platform 15-20 miles high which would be supported by gigantic hydrogen balloons. You would then take off horizontally and travel into space from there since most of the energy costs are the first 10 miles . A lightweight cable would be connected from the ground to the platform and carts could move up and down in order to transport whatever. Would this be a more cost effective approach to a space elevator, or is the amount of hydrogen and balloons required simply unfeasible economically?
The platform would be constructed on the ground at first, and then materials would be gradually transported up the cable, as the platform ascends, to produce additional hydrogen gas via some chemical reaction. Perhaps the cable could be hollow and hydrogen gas could be generated on the ground and then pumped up to the platform. It would probably take a couple years to reach the ideal height and becomes exponentially more difficult the higher in the atmosphere one goes . Some point would need to be calculated to determine the most cost effective altitude.
Additionally, you could also glide from one of these platforms to some arbitrary location and cut fuel costs immensely while saving the environment. Is this a terrible idea? If so please explain the economic reasons.
Astronomy news on Phys.org
"since most of the energy costs are the first 10 miles"
The statement is incorrect. Air resistance, yes, most of that is gone rather quickly, but the gravitational well is much deeper than 10 miles. (Theoretically) lifting something straight up from the surface of the planet it won't stay in place until the height is equal to geostationary orbit...
Most fuel is needed for the horizontal velocity of about 8km/s. Getting up to ~400km is about 10% of this, and getting up to 20km is 5% of this 10%. All you would save is some air resistance.
Are spaceports built on high mountains? No. The logistics effort is worse than the additional fuel needed to start close to sea level (Cape Canaveral and French-Guiana at the coast, Baikonur just at 100m above sea level, ...).
Some confusion might come from the fact that a lot of small rockets are launched from helium balloons in or near the stratosphere. While I'm not sure, I suspect that such is done to avoid the cost and complexity of using multiple stages rather than simply the amount of fuel required.
TL;DR Summary: In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect alien signals, it will further expand the radius of the so-called silence (or rather, radio silence) of the Universe. Is there any sense in this or is blissful ignorance better? In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect...
Thread 'Could gamma-ray bursts have an intragalactic origin?'
This is indirectly evidenced by a map of the distribution of gamma-ray bursts in the night sky, made in the form of an elongated globe. And also the weakening of gamma radiation by the disk and the center of the Milky Way, which leads to anisotropy in the possibilities of observing gamma-ray bursts. My line of reasoning is as follows: 1. Gamma radiation should be absorbed to some extent by dust and other components of the interstellar medium. As a result, with an extragalactic origin, fewer...
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
