Can you say photons "become" phonons? Not all photons are absorbed by the material creating vibrational atomic resonances known as 'phonons'. (specific conditions need to be met like intensity).
Why not? After all, the propagation of the wave through the material is soley done by interaction with the material...hence the change in speed...
To argue against it being a phonon, we would have to say that it doesn't interact at all...
if it doesn't interact, then how is it that the material is able to act so efficiently as a filter to some momentum and not others? I'm going on the basis that any wave propagation in a material is a phonon and not a photon...i could be wrong, but as long as the wave exists within the boundry, then it remains a phonon...I'd welcome advice from experts in the area on this.
I found this link interesting in looking at optical and acoustical modes.
(web page addy: chembio.uoguelph.ca/educmat/chm729/Phonons/cont.htm)
I assume you are defining how the polarization of the incident light is defined as it propagates through the material? That being said, all light is polarized upon exit of any crystal?
I'm not sure on the all light is polarized bit, what i am saying there, or doing rather is giving an example of a mode of travel through a material...using a crystal as a clearer example.
While glass isn't your highly organised structure, it doesn't prevent it from being somewhat arranged. The atomic arrangements within the glass are, agreed, more amorphous and so we don't get those lovely channels as we do in crystals...what i don't know is whether this presents minute surface boundary conditions in the material that the wave has to negotiate...however, the overall field arrangement is such that it allows propagation from one surface to the other unless there is a distinct breakdown within the glass.
i think its easy to see the photons being transmitted soley by the electrons, and more difficult to see that its the field that's doing all the work. I don't think the major work done in transmission is via absorption and then retransmission by the electron. The delays produced by this would be significant to say the least. This would also set a greater limit on the number of photons allowed to pass at anyone time...I just don't see this myself...and i must be careful here not to venture into what i believe rather than what is proven experimentally...but to stick my toes in a bit...
warning! conjecture!
when a wave passes an electron, i assume the behaviour is like that of a cork on water wherein it responds to the passing field of the wave and there is some affinity or lack of exerted, as well as a dependence on its previous or natural state of vibration, with respect to the passing wave . It is this interaction that determines 1. it propagtes on, 2. gets absorbed or 3. is resisted.
it doesn't actually need to touch the charge body, just the fields need to interact.
does this make sense at all? because in viewing this, I'm imposing the limit that the photon/phono is completely wavelike in nature.
A random structured material (eg. glass) would then have a higher probability of absorption/scattering than an ordered structure (crystal). Yet, some crystals appear more opaque at white light than ordinary glass.
Yes i agree that it looks upside down, but let's face it, we know looks are decieving...
but the proof as far as I'm concerned is in the pudding...;)
A great example is the piezo effect (field effect) of many crystals...one optical use of this is found in Q-Switched lasers. By applying a voltage field or an acoustic wave, depending on the material, they can influence the light's passage.
I take it that they have realigned the electronic fields within the cyrstal and so present a resistive/assistive field to the waves.
What may appear opaque to the visible portion of the spectrum may infact be completely clear to the infrared or microwave portions or it could be that the fields are arranged such that 1. the majority EM is absorped or 2. reflected.
In the case of scatter, as is obvious when white light then gets jumbled to become milky...this suggests a completely disorganised field or possibly one that has many different field structures though organised. Sort of like a staircase that has many steps of different sizes and directions.
ZapperZ was saying that the amorphous structure of glass prevents the excitation of vibrational modes within the material, now this would mean that Laser Microphones (based on the principle of opto-acoustic modulation) would work better on Crystals than standard window glass. And normal glass has a fairly decent SNR for those laser microphones (I've tried it).
What do you think?
I'm not going to disagree with zapperZ at all on the modes issue and I think i have covered pretty much what i think in showing that what may be amorphous can in fact be organised though its atomic arrangements do not lend the idea easily.
i believe the discontinuity of effects you describe are covered if we view it as fields rather than picture perfectly organised charge bodies.
I can easily twang any nearly any material with an ultrasound wave and examine it for defects...admittedly, its not a optical phonon but a phonon nevertheless.
my point being that though photonics require lovely discrete modes on which to build devices geared to the semiconductor industry, it doesn't mean that we cannot make use of the natural field arrangement that materials make use of all the time when conducting all manner of EM radiation...ie heat, light and so on...
My only other addition is that i believe, not sure I'm right but, that the higher you get in frequency, the more the wave tends towards the particle effect and hence why at energies above xray...ie gamma...we see more billiard ball effects and the scattering becomes more important...
opto-acoustic behaviour is best in peizo type materials which aren't neccesarily pure crystal objects...most piezos are made by heating a mixture of powders and allowing them to cool, much the same way as glass is made...so i expect that both would have similar effects...in this case, i think its radiation pressure that's the pronounced behaviour...have a look at photo-acoustic spectroscopy to see what's happening there and you will see the similarities.
I would have thought that any material under pressure would distort...see what i am saying?
we need some optical experts to clear up our thoughts...:)
