Unsure of how to compare non-paired values
  • Thread starter Thread starter Richter915
    Compare
Richter915
I am currently trying to show that two numbers are significantly different but I am unsure of how to do the statistics. I'll provide a brief description below.
I have 4 arrays: Array A Array B Array C and Array D
I can determine the difference between 2 arrays using a student's t-test
From each value within each array, I performed a simple mathematical calculation - let's just say I took the natural logarithm of each value.
I now have four new arrays which is from the calculations done on each value, Array A' Array B' Array C' and Array D'
Again, I can do a pairwise analysis of pairs of arrays using a student's t-test to determine significance.
What I want to do now is take the difference between two arrays (A' and B') and compare that to the difference between the other two arrays (C' and D'). Now, I can't simply take the difference in a pairwise manner (as in, value one of A' minus value one of B') so I have to take a difference of means.
So now I've generated the difference of these two means but I do not know how to do the variance of this value or to determine if these difference of means values are actually different from one another.
I've tried using propagation of uncertainty in order to determine uncertainty of these values but I am unsure if this is the best way. Either way, I am unsure if these values are significantly different.
Any help on this would be appreciated. Thanks.
You haven't explained your problem clearly. I suggest you try again.
For example, you say you are trying to find if two numbers are significantly different, but you mention 4 arrays of numbers. Also, you say you transform the numbers in the arrays and get new arrays, but you say you "can't simply take the difference in a pairwise manner (as in, value one of A' minus value one of B' " and it isn't clear whether you mean that this operation is impossible or whether it is possible, but, for some reason, not meaningful.
Hi all, I've been a roulette player for more than 10 years (although I took time off here and there) and it's only now that I'm trying to understand the physics of the game. Basically my strategy in roulette is to divide the wheel roughly into two halves (let's call them A and B). My theory is that in roulette there will invariably be variance. In other words, if A comes up 5 times in a row, B will be due to come up soon. However I have been proven wrong many times, and I have seen some...
Thread 'Detail of Diagonalization Lemma'
The following is more or less taken from page 6 of C. Smorynski's "Self-Reference and Modal Logic". (Springer, 1985) (I couldn't get raised brackets to indicate codification (Gödel numbering), so I use a box. The overline is assigning a name. The detail I would like clarification on is in the second step in the last line, where we have an m-overlined, and we substitute the expression for m. Are we saying that the name of a coded term is the same as the coded term? Thanks in advance.
