Solv. Calibration Curve Problem for Unknowns: A-E
  • Thread starter Thread starter kynephrus
    Urgent
The discussion centers on a calibration curve issue encountered during a UV-Vis analysis of caffeine. The calibration curve equation derived is y = 0.0002x + 1.5033, but the slope is deemed ineffective due to its low value and the offset being significantly high, indicating a non-linear response. The user is struggling to extrapolate the concentration of unknown samples, as plugging in absorbance values results in unrealistic negative concentrations. It is suggested that the calibration should be adjusted to pass through zero, in accordance with Beer's law, to yield valid results. The overall consensus is that the current calibration curve is not suitable for accurate concentration determination.
kynephrus
I don't know if this is the right place to post such a question, but I saw a couple of other similar questions, so I figured I would give it a shot.
My problem has to do with a calibration curve. My lab partner and I just did an analysis using UV-Vis on caffeine. We constructued a calibration curve using linear regression, the equation of the line being:
We are trying to extrapolate the concentration of an unknown using this equation and the absorbencies obtained for the unknown. I know theoretically I should just plug the absorbancy into y and solve for x, but the absorbance is so small, whenever I try I get a really negative number, in the 6000. Am I doing something wrong? Is there a way to use this number even though it is negative?
The absorbancy of the various unknowns are:
a=0.118988
b=0.225891
c=0.305755
d=0.234054
e=0.226928
if someone can help me with this is would be greatly appreciated. I've pretty much run out of sources and ideas.
What are all the units (y and x)? What were the extremum points of the calibration data? How good was the linear fit (do you have a value for RMS error or chi-square)?
Right off the bat I notice that the slope of your regression line is good to only 1 sig fig. That doesn't look encouraging. Consider fixing that.
It is worse than that, I'm afraid. The slope of this line is close to zero and the offset is 1.5 absorbance units! 1.5 absorbance units is waaay into the nonlinear range. You will never be able to do anything with this calibration line. Your calibration should be forced to go through zero since Beer's law states that absorbance = (path length)X(concentration)X(absorptivity). the path length is constant as is the molar absorptivity so combining them gives you an equation something like absorption = (constant)X(concentration) + 0
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
