USB Hub Noise Filter: Reduce 500mV Amplitude & 10MHz Frequency
The discussion revolves around addressing noise issues in a wireless sensor powered by a USB hub. Participants explore potential solutions to reduce noise amplitude and frequency, focusing on circuit design, filtering techniques, and grounding issues. The scope includes technical explanations, proposed circuit modifications, and considerations for component selection.
  • One participant suggests using a linear Low-Dropout Regulator (LDO) to create a quieter 3.3V supply if the sensor can operate at that voltage, or a boost DC-DC converter to increase the 5V input to 8V before regulating it back down.
  • Another participant notes that the sensor has an internal LDO and decoupling capacitors, but noise still penetrates, raising concerns about grounding and the impact of a long USB cable on ground noise.
  • Some participants discuss the importance of layout in RF circuit design, emphasizing the need to minimize ground impedance between RF and digital circuits.
  • There are suggestions to add smaller capacitors (47 or 100nF) alongside existing decoupling capacitors to improve noise filtering.
  • One participant expresses uncertainty about selecting an appropriate inductor for filtering, acknowledging the presence of stray capacitance in inductors.
  • Concerns are raised about the dropout voltage of the LDO and its noise rejection specifications, with requests for schematic and layout sharing to better understand the circuit design.
  • Another participant emphasizes the need for capacitors to be placed close to the connector to effectively shunt noise, suggesting that smaller capacitors may provide a lower impedance return path for high-frequency noise.
  • Discussion includes the potential for stray pickup on oscilloscopes affecting measurements, and the need for bypassing larger electrolytic capacitors with smaller high-frequency capacitors.
Participants express a range of views on the best approaches to mitigate noise, with no clear consensus on a single solution. Various filtering techniques and component choices are debated, indicating multiple competing perspectives on the issue.
Participants highlight limitations in their current setups, including the impact of long USB cables on ground quality and the effectiveness of existing decoupling strategies. There is also mention of the need for specific component specifications that have not been provided.
Electronics designers, engineers working with RF sensors, and hobbyists interested in noise reduction techniques in power supply circuits may find this discussion relevant.
  • #31
  • #32
Rive said:
Ugh. I think what you are trying to repair here is not your circuit but your equipment. Please try to power it from a different source (for example, from the computer you are using to access this forum).
Hi Rive,
I have a USB off-line AC power supply I have selected for this product. The power supply works fine. When I power the sensor from the hub temperature reading on my device changes significantly. The noise generated inside the hub affects circuits inside.
Thank you.
  • #33
gnurf said:
Jim,
I think you'll be hard pressed to find a practical ferrite that will be effective across the bandwidth in question. I agree that stray capacitance of a series L is not a concern, but not for the reason you state; the unwanted parasitic capacitance will be in parallel with the inductive element, providing a low-impedance path past it, so the downstream capacitance (10uF) will not swamp it. The reason I agree to not worry is that I don't think it will be a problem at these low frequencies (unless you completely botch the layout of course, but that's another story). What do you think about that?
Hi Jim, hopefully, the layout is not too messed up. I have ground plane polygons on the internal layers. They make about 70-80% of the surface area of layers 2 and 3. I think a large inductor or maybe 2 inductors on 5V and GND lines could help to reduce the noise. I am not sure about the values of inductors to use. The load current is about 350mA.
Thank you
  • #34
jim hardy said:
just fishing...
from TI datasheetView attachment 230012
View attachment 230013to your question about an inductor
even a ferrite bead would help.
Dont obsess about its stray capacitance, your 10μf should swamp it. I'd worry more about Z of that single via..
Scope check might reveal something.
old jim
Hi Jim, I am going to order a demo board for the TPS73701DCQR, TPS73701DRVEVM-529, to verify my layout. If the output from the demo board is not noisy, then I have a layout issue.
  • #35
chakr said:
Noise is fun to deal with.
I don't think you can get a good measurement anyplace near that USB hub.
You did the experiment i was hoping you would
that thing is radiating so intensely it induces voltage in your 'scope probe. A few feet of separation might help.
I'd say try powering your gizmo from a battery if you can find one that's not over the 6 volt absolute maximum rating and preferably not over the 5.5 recommended maximum operating.
Maybe series up three AA's ?
If that helps get a 4.5 or so volt "Wall Wart" that's linear (line frequency transformer and rectifier inside) . You can tell them from switchers they're about twice as heavy. Thrift shops are full of them .
First you might try placing a copper clad iron skillet over the USB hub for an EMI shield. That ought to be nice and lossy at 100 khz
Keep on having fun ! It feels so good when you conquer a pesky problem like this.
old jim
  • #36
Well, on the picture you have attached previously that terrible thing on the screen of your 'scope is picked up through a classic one-turn loop? ...
... to be honest, your circuit with that LDO looks 'good enough' for most application. Of course, it is not able to make up for excess mistreat, that would require more circuits added.
If you are interested in your hub then maybe you should dissect that instead? (I'm too interested. Slightly.)
But my practical side keeps saying that you should just dispose of it.
Ps.: just one important remark. That's no HUB. That's a CHARGER. Things are not expected to work when attached...
  • #37
I
I agree, my mistake. The problem is that people plug in the device into anything that has a USB port in it and not everything works :).
  • #38
chakr said:
II agree, my mistake. The problem is that people plug in the device into anything that has a USB port in it and not everything works :).
Which is why immunity is part of any EMC spec...
The world is a noisy place so products that are expected to work in that world need to not cease operating at the first hint of some radiated or conducted EMI.
Input filters are your friend.
  • #40
looks to me like it has eight or ten USB slots on it
so i don't know what it is for sure
did he ever give us details on it ?
Isn't USB standard 5 volts DC at about an amp ?
  • #41
old jim
Yes, in the picture it is the hub. It is actually a 5V charger. The unit has an option to run from AA batteries. Sometimes it needs to run from AC. This charger has both conducted and EMI noise. Such a poor design. I opened it. It looked inside very unattractive.
  • #42
Hi everyone,
I am placing an order for some inductor chokes and ceramic capacitors. If I am successful, or should I say when I succeed, I will post my solution. I am also placing an order for a demo board with my LDO to verify if I make a layout error.
Thank you, everyone. It was a great help.
  • #43
gnurf said:
https://psearch.en.murata.com/capacitor/product/GRM188R60J106ME47#.html
That 10μF capacitor, with 5V applied, is less than 3μF. See the third graph "DC bias characteristics" in the datasheet.
Also the capacitor has a self resonant frequency of 2MHz, so it will be less effective above that frequency. See the first graph "Frequency characteristics |Z|" in the datasheet.
The root problem seems to be that switching power supply, the scope trace indicates it is bottom-of-the-barrel quality. Replace it.
Cheers,
Tom
  • #44
That's the general idea, yes.
However, since most device which people would connect to a charger has battery (what can make up for many problems from a wicked input voltage), something 5V-ish is frequently considered market-ready as long as it can provide charging current for cheap (and at least a week long).
  • #47
Cheers,
Tom
I am going to find a better capacitor. RF type.
  • #48
I would try adding something like a 100nF in parallel. Just solder it to the existing capacitor.
  • #49
Yes, as in a disc ceramic. Put one at each of the connectors in the hub too, they will probably do more good there than in your external device.
  • #50
Hi, I tried different ways to fight the noise. In the end, the only thing that actually helped is Earth ground. I connected my device ground return to an Earth ground through Y-type capacitors. It reduced the noise to acceptable levels. The only thing is that this solution is not practical in my case.
13K
  • · Replies 21 ·
13K
  • · Replies 85 ·
10K
