USB Hub Noise Filter: Reduce 500mV Amplitude & 10MHz Frequency
A designer is experiencing significant noise on a 5V USB power line affecting the accuracy of a wireless sensor, with noise frequencies detected between 10MHz and 100kHz and an amplitude of 500mV. Recommendations include using a linear Low-Dropout Regulator (LDO) for a quieter voltage supply and adding capacitors close to the LDO to filter out high-frequency noise. Discussions highlight the importance of grounding and layout to minimize noise interference, suggesting that a long USB cable could contribute to ground noise. The use of inductors or ferrite beads is considered to further reduce noise, though layout and component placement are emphasized as critical factors. Overall, addressing the noise issue involves a combination of filtering techniques and careful circuit design.
chakr
Hi,
I designed a small wireless sensor that can run from 5V USB power. I use a USB hub to power my device via a USB cable. There is so much noise on the 5V USB line that my device readings turn inaccurate. Using the oscilloscope I can see noise frequencies of 10MHz and down to 100kHz, assuming the scope gives me accurate frequency values. The noise amplitude is almost 500mV.
Can anyone recommend a circuit that can help to get rid of the noise?
Thank you.
chakr said:
Hi,
Thank you.
Can your sensor run on 3.3V? If so, use a linear Low-Dropout Regulator (LDO) to make a quiet 3.3V supply for your sensor.
If not, use a boost DC-DC converter to boost the 5V input up to 8V or so, then use a linear regulator to make a quiet 5V rail for your sensor.
What kind of sensor is it? If it is wireless, why not run it off of a battery instead of the USB power?
Hi, thank you for your reply. The sensor has an internal LDO which steps the voltage down to 3.3V. I have a 10 and 100 uF decoupling caps at the output of the LDO. The noise still gets through. The unit can run off of a battery, but when USB is plugged in the battery gets disconnected from the main circuit.
If I connect unit ground to AC ground the problem seems to go away, but this is not a viable solution in my case.
Thank you again
Thank you again
There are some subtle tricks in laying out an RF circuit/sensor. I've worked on product designs for RF sensors in the past, and we had to get a few things right or our RF section was desensitized badly (many 10s of dB). If done correctly, you should not be getting noise through the LDO regulator -- that is what they are used for. It does sound like the grounding may be the issue. You need to be sure that the RF circuit and any digital circuit on the layout do not share any ground impedance, for example...
Likes AlexCaledin
I see I need to verify the ground inside the unit. The Sensor unit is powered from a USB hub and it has a common ground with the Sensor internal circuitry. There is a long USB cable between the USB hub and the unit. I wonder what it does to the unit ground? The long USB cable, does it make the ground noisier or less effective?
Thank you.
I always thought one uses inductors to filter out high frequency noise, what am I missing?
May not be a cure but perhaps try some 47 or 100nF caps as well as the existing 10/100uF. Ideally should also be caps on both sides of the LDO.
Hi, that is what I want to try next. The noise frequency is up to 10MHz with 0.5V amplitude. It is a very noisy USB hub. I am not sure how to select a propper inductor. I know that inductors are not perfect and there is a stray capacitance present in them. I want to try a relatively large inductor, but I am worried that parallel capacitor will become a dominant component.
Thank you.
What is the dropout voltage of the LDO? Does it have any specs for input-output noise rejection over frequency?
Can you share the schematic for this board? Can you share the layout?
If you have a working prototype, I'd try to shunt off the noise with capacitors as close as possible to the connector (on the input side of the LDO). Try to minimize the mounting inductance, but even a less-than-perfect implementation should give you instant hope if there is any. You already have plenty inductance in the cable which will act as the L in your LC filter, so I'd worry about adding bulky inductors later.
Thank you, I agree about the cable. I do have a 10uF cap 15-20 mil from the part, almost on the part. Should I make it larger?
No, you should make it smaller. As in physically smaller which means low inductance which is what you need to have a low impedance return path for the high-frequency harmonics (noise) you're most likely seeing. Actually, I'm not talking about the bulk 10uF capacitor on your LDO input (the location of which is probably irrelevant here and in general), I'm talking about adding a filter to your connector in an attempt to attack the problem as close as possible to the source.
I'd try this first and go from there.
I can add a separate filter circuit between the USB cable and the Sensor node. Do you think it will help?
Switching power supplies are electrically noisy.
Make sure you're not seeing stray pickup on your scope
by connecting both the 'scope probe and its little ground clip to same signal common point on your gizmo
If it's quiet, ie no noise, then you have capability of decent 'scope measurements.
If it's quiet then move scope probe to +5 line but leave the ground clip on common.
C33 is probably electrolytic and will need to be bypassed by a small high frequency capacitor.
That's because electrolytics are made by rolling a strip of aluminum into a coil and inserting that into a tube.
That coil has a tiny amount of inductance and at high frequency the inductance becomes significant impedance.
Seems crazy to bypass a 10 with a 0.1 but that's how it is done.
Used to be we wouldn't use a switcher with analog measuring equipment.
Of course i might be all wet. But i have chased a lot of noise over the years.
old jim
Likes Klystron and CWatters
Thank you, I can try that.
old jim
Thank you, Jim
C33 is a ceramic cap (GRM188R60J106ME47D) . I will try to place my scope the way you recommend. C33 is very close to the LDO. C33 goes straight into the ground via a VIA connection.
Likes jim hardy
chakr said:
[...] C33 is a ceramic cap (GRM188R60J106ME47D) [...]
This makes me less optimistic about my initial thoughts about adding low-inductance capacitance right at the input of the connector, as the sole solution. I'd still attack the noise on VBUS close to the connector, but perhaps a (bulky) series inductor will ultimately be necessary in addition to the cap. The cap-only solution is very easy/cheap to try, which is why I suggested that first. Does it have any effect at all? Also note that the effective capacitance of GRM188R60J106ME47D [1] is 3uF with a 5V DC bias, and not 10uF as you maybe think it is. The little snippet of your PCB layout does not reveal enough to be helpful. In fact, there's a lot to be said about layout here, for all we know you've split your ground plane in some ludicrous way etc etc--small things that alone could kill your design.
Did you explore the noise rejection ratio of your LDO as berkeman suggested?
[1] https://psearch.en.murata.com/capacitor/product/GRM188R60J106ME47#.html
How is that hub powered? Can you attach your sensor to a PC for a short test? Are you sure you don't have a ground loop somewhere (maybe through your oscilloscope)?
Ps.: How does the power looks like on the input side of the hub? How does it looks like on the output side without your device?
chakr said:
Thank you, Jim
Well i didnt expect that ! Bravo ! good choice.
just fishing...
from TI datasheet
to your question about an inductor
even a ferrite bead would help.
Dont obsess about its stray capacitance, your 10μf should swamp it. I'd worry more about Z of that single via..
Scope check might reveal something.
old jim
Jim,
I think you'll be hard pressed to find a practical ferrite that will be effective across the bandwidth in question. I agree that stray capacitance of a series L is not a concern, but not for the reason you state; the unwanted parasitic capacitance will be in parallel with the inductive element, providing a low-impedance path past it, so the downstream capacitance (10uF) will not swamp it. The reason I agree to not worry is that I don't think it will be a problem at these low frequencies (unless you completely botch the layout of course, but that's another story). What do you think about that?
That would make a capacitive voltage divider . Picofarads of stray capacitance and microfarads of intentional capacitance in series - which one incurs the majority of voltage drop ?
i think we're dancing around the same concept. If your C33 doesn't have another impedance in series from stray inductance then its impedance will be way less than that of the stray capacitance around your inductor...
For your 100khz switching noise a bead certainly is underkill.
My thought was to pirate one out of some scrap electronics and see if it reduces the high frequency hash your 'scope is reporting...
First thing though is to see if 'grounding' scope probe at the circuit common cleans up the trace.
If it does you've probably been picking up radiated noise through the air and might call that 'measurement error' ..
http://www.analog.com/en/analog-dialogue/articles/ferrite-beads-demystified.html
old jim
Adding a filter is what I'd do, it should actually be your default reaction to any off board signals.
Do you know if you are dealing with common mode or differential mode noise? I'd bet its common mode, which is a pain.
Anyway, Id put a small cap directly on the 5v to gnd where it comes on your board. Then add series BLM in series with both the 5V and GND, then keep the 10u ceramic and add a few smaller caps in parallel to give you better performance at higher freq. The 10u has a self resonance at ~2Mhz, 0.1u 0603 sits around 20Mhz, 10n ~90Mhz.
Place the filter as close to where the offending signal are coming on to the board and do not put any internal traces near these unfiltered dc inputs to avoid coupling the noise back in via the PCB. You'll want the small caps close to the filters rather than the LDO, they just need some large capacitance to for stability and aren't overly fussy when it comes to high speed decoupling, esp if your load is slow or sufficiently decoupled.
Then if you're not drawing much current from the 5V rail, even series resistance of a few ohm to 10's of ohm in series with each BLM will really help the caps filter noise from your supply, you can put down a couple of 0603 resistors and put zero ohm links in if the BLM's are enough.
Hi, I tried to add a capacitor to the USB connector. Unfortunately, it didn't help. The ground areas on the top layer are broken because I have components. Internal layers have continuous ground planes, but I do not have a dedicated ground layer. Maybe that is the problem? My choice of the input decoupling cap seems to be wrong.
Thank you for your advice. Noise is fun to deal with.
Hi Rive, the hub is powered from straight AC. I have attached an image from my scope that shows the noise. The scope shows noise from the hub even when it is not connected to my device.
Ugh. I think what you are trying to repair here is not your circuit but your equipment. Please try to power it from a different source (for example, from the computer you are using to access this forum).
  • #31
  • #32
Hi Rive,
I have a USB off-line AC power supply I have selected for this product. The power supply works fine. When I power the sensor from the hub temperature reading on my device changes significantly. The noise generated inside the hub affects circuits inside.
Thank you.
  • #33
gnurf said:
Jim,
Hi Jim, hopefully, the layout is not too messed up. I have ground plane polygons on the internal layers. They make about 70-80% of the surface area of layers 2 and 3. I think a large inductor or maybe 2 inductors on 5V and GND lines could help to reduce the noise. I am not sure about the values of inductors to use. The load current is about 350mA.
Thank you
  • #34
jim hardy said:
just fishing...
from TI datasheetView attachment 230012
View attachment 230013to your question about an inductor
old jim
Hi Jim, I am going to order a demo board for the TPS73701DCQR, TPS73701DRVEVM-529, to verify my layout. If the output from the demo board is not noisy, then I have a layout issue.
  • #35
I don't think you can get a good measurement anyplace near that USB hub.
You did the experiment i was hoping you would
that thing is radiating so intensely it induces voltage in your 'scope probe. A few feet of separation might help.
I'd say try powering your gizmo from a battery if you can find one that's not over the 6 volt absolute maximum rating and preferably not over the 5.5 recommended maximum operating.
Maybe series up three AA's ?
If that helps get a 4.5 or so volt "Wall Wart" that's linear (line frequency transformer and rectifier inside) . You can tell them from switchers they're about twice as heavy. Thrift shops are full of them .
First you might try placing a copper clad iron skillet over the USB hub for an EMI shield. That ought to be nice and lossy at 100 khz
Keep on having fun ! It feels so good when you conquer a pesky problem like this.
old jim
  • #36
Well, on the picture you have attached previously that terrible thing on the screen of your 'scope is picked up through a classic one-turn loop? ...
... to be honest, your circuit with that LDO looks 'good enough' for most application. Of course, it is not able to make up for excess mistreat, that would require more circuits added.
If you are interested in your hub then maybe you should dissect that instead? (I'm too interested. Slightly.)
But my practical side keeps saying that you should just dispose of it.
Ps.: just one important remark. That's no HUB. That's a CHARGER. Things are not expected to work when attached...
Likes jim hardy
  • #37
I
I agree, my mistake. The problem is that people plug in the device into anything that has a USB port in it and not everything works :).
  • #38
chakr said:
II agree, my mistake. The problem is that people plug in the device into anything that has a USB port in it and not everything works :).
Which is why immunity is part of any EMC spec...
The world is a noisy place so products that are expected to work in that world need to not cease operating at the first hint of some radiated or conducted EMI.
Input filters are your friend.
  • #40
looks to me like it has eight or ten USB slots on it
so i don't know what it is for sure
did he ever give us details on it ?
Isn't USB standard 5 volts DC at about an amp ?
  • #41
old jim
Yes, in the picture it is the hub. It is actually a 5V charger. The unit has an option to run from AA batteries. Sometimes it needs to run from AC. This charger has both conducted and EMI noise. Such a poor design. I opened it. It looked inside very unattractive.
  • #42
Hi everyone,
I am placing an order for some inductor chokes and ceramic capacitors. If I am successful, or should I say when I succeed, I will post my solution. I am also placing an order for a demo board with my LDO to verify if I make a layout error.
Thank you, everyone. It was a great help.
Likes jim hardy
  • #43
That 10μF capacitor, with 5V applied, is less than 3μF. See the third graph "DC bias characteristics" in the datasheet.
Also the capacitor has a self resonant frequency of 2MHz, so it will be less effective above that frequency. See the first graph "Frequency characteristics |Z|" in the datasheet.
The root problem seems to be that switching power supply, the scope trace indicates it is bottom-of-the-barrel quality. Replace it.
Cheers,
Tom
Likes jim hardy
  • #44
That's the general idea, yes.
However, since most device which people would connect to a charger has battery (what can make up for many problems from a wicked input voltage), something 5V-ish is frequently considered market-ready as long as it can provide charging current for cheap (and at least a week long).
  • #47
Cheers,
Tom
I am going to find a better capacitor. RF type.
  • #48
I would try adding something like a 100nF in parallel. Just solder it to the existing capacitor.
Likes Tom.G
  • #49
Yes, as in a disc ceramic. Put one at each of the connectors in the hub too, they will probably do more good there than in your external device.
  • #50
Hi, I tried different ways to fight the noise. In the end, the only thing that actually helped is Earth ground. I connected my device ground return to an Earth ground through Y-type capacitors. It reduced the noise to acceptable levels. The only thing is that this solution is not practical in my case.
