Use a motor to turn a threaded rod
  • Thread starter balsaboom
    Motor Rod
6 replies · 7K views · last reply
balsaboom
Hi everyone,
Is this something that I can use to link a motor to a threaded rod (so when the motor turns, the threaded rod turns as well)?
also, about how much torque will i be needing to slowly rotate a 1 foot steel threaded rod?
Thanks
This is known as a "motorized lead screw". The torque to drive it depends on the load you are moving plus the friction of the system.
I just did a quick google search of "motorized lead screw" and I didnt find much. Could you provide a photo or a link with some more info?
Also, I'm not turning any load, just a threaded rod. A normal stepper motor should be fine, right? I particular I am eyeing http://www.maplin.co.uk/miniature-epicyclic-motorgearboxes-43376 (the one with the lowest rpm)
thanks again for all your help!
balsaboom Excuse me, I did not read your post carefully and missed your point completely. So, you are looking for “couplings to link the motor shaft (4mm / 5/32") to the 1/4" threaded rod”.
What you can use is called an “Inch/Metric Universal Lateral Shaft Coupler”. Here is a catalog with many to choose from:
PIC Design Catalog 45, Lateral shaft couplers, Section 7 which contains these types:
Bellows Couplings, Zero Adjustable Couplings, Flexible Couplings, Miniature Oldham Couplings, Wafer Oldham Couplings, Universal Lateral Couplings, Multi-Jaw Couplings, Precision Universal Joint Couplings, Molded Universal Joint Couplings, Precision Sleeve Couplings, Flexible Zero Backlash Couplings, Spider Couplings
You’ll need to get the pdf document and then scroll down to Section 7. There you can choose the right one for your project.
Good Luck, Bobbywhy
Good Luck, Bobbywhy
great, that was exactly what i needed. thanks!
